Results 51 to 60 of 307
15th December 2008, 12:18 PM #51
Re: Review of the Samsung HM160HC, World's Fastest ATA/IDE Mobile hard drive
Real world performance is influenced by acces times AND throughput AND I/O. Let's say, for example, 50% throughput 25% access times 25% I/O like suggested by Toms Hardware.
So a 15ms vs. 18 ms acces time is nice, but can be equalled out if the 18ms drive has higher throughput.
I upgraded from Seagate 80GB 7200.1 to Samsung HM160HC. I can tell you my system boots faster and hibernates faster. Application launching is about the same.
PCMark is a benchmark application that weighs in throughput, acces times and IO. As you can see in the attachment the HM160HC beats the 80GB 7200.1 in most situations. In application launching they are virtually the same.Last edited by Phil; 15th December 2008 at 12:25 PM.
15th December 2008, 05:03 PM #52Newbie
- Join Date
- Dec 2008
- Posts
- 8
- Rep Power
- 11
Thanks for the quick reply Phil, you've rekindled my hope that I can upgrade the size of my laptop without downgrading the speed. So I take it that your opinion is that switching out my Hitachi 7k60 for a HM160HC or a WD25000BEVE would result in general use/application loading/file browsing being the same or improved?
15th December 2008, 05:13 PM #53Notebook Prophet
- Join Date
- Apr 2008
- Location
- England
- Posts
- 6,399
- Rep Power
- 40
Greatly improved. The old 7K60 was so painfully slow on my laptop. I upgraded to the WD3200BEVT which performs the same as the HM160HC, and the difference in performance was massive.
15th December 2008, 05:13 PM #54
It will improve. Because as far as I know the Seagate 7200.1 80GB is already faster than the 60GB Hitachi 7K60. No doubt you'll see improvement.
15th December 2008, 05:27 PM #55Newbie
- Join Date
- Dec 2008
- Posts
- 8
- Rep Power
- 11
Thanks for the info guys,
Phil, I can't seem to respond to your PM as I'm a new member, but to answer your question, I did run HD Tune on my 7k60 which came up with
HD Tune: HTS726060M9AT00 Benchmark
Transfer Rate Minimum : 11.4 MB/sec
Transfer Rate Maximum : 39.0 MB/sec
Transfer Rate Average : 29.7 MB/sec
Access Time : 15.2 ms
Burst Rate : 79.5 MB/sec
CPU Usage : 2.4%
15th December 2008, 05:28 PM #56Newbie
- Join Date
- Dec 2008
- Posts
- 8
- Rep Power
- 11
I was hoping to just retain the same speed with an improved storage space, it's quite nice to know that I might be getting a boost in performance as well
15th December 2008, 05:41 PM #57Notebook Prophet
- Join Date
- Apr 2008
- Location
- England
- Posts
- 6,399
- Rep Power
- 40
Oh wow. I have the HD Tune graph as well somewhere. The HM160HC will be nearly twice as fast.
It will be more of a kick (A55) in performance, rather than a boost.
15th December 2008, 05:46 PM #58Newbie
- Join Date
- Dec 2008
- Posts
- 8
- Rep Power
- 11
Well that is indeed quite exciting. The relatively low access time and high burst rate on my current drive in comparison to the 5400 drives in question led me to believe an upgrade would slow me down for everything aside from moving large files. I'm glad there's more to it than that, and I can upgrade without worry. Now I suppose it's just a question between the HM160HC and the WD2500BEVE.
16th December 2008, 02:41 AM #59
I wouldn't say twice as fast (because acces times are important too) but the HM160HC will be noticeably faster than your 7K60. The HM160HC gets about 51 MB/sec average.
Between the WD2500BEVE and HM160HC, Samsung all the way. Single platter, better power consumption, less noise and faster.
16th December 2008, 02:51 AM #60Hi, I'm Jimmy Diesel ^_^
- Join Date
- Sep 2007
- Location
- Rensselaer Polytechnic, and Huntington, NY
- Posts
- 8,077
- Rep Power
- 50
When I had the 7K100 in my Dell inspiron 8500 (the test machine all of the benchies were made on), I noticed a decent performance gain by upgrading to the HM160HC.
It is not 2x as powerful as the 7K100 I had, but its noticeably faster. Adobe CS2 loads about 15 seconds faster on the HM160HC, than on the 7K100, and windows boots about 16 seconds faster with the Hm160HC, (total boot time is ~38 seconds)
The 40gb 5400rpm drive took about 1 minute 50 seconds to boot,
and the 7K100 took just under a minute (~55 sec) to boot.
The 7K100 is fairly faster than the 7K60 you have (~10mb/sec faster), so you will definitely notice quicker response from the system and shorter loading times.
K-TRONDell E1505: Intel T7600G @ 3.16GHz, 4GB PC6400, Crucial M4 512GB SSD, ATI X1400
Detroit Diesel 5.2L 6V53T with N70 injectors: 1650LBs of American Muscle (330HP @ 2650rpm, 775lb/ft @ 1600rpm) - waiting on a 51 Hudson
1979 GMC 7000 Motorhome: 170hp 4-53T Detroit Diesel, Spicer CM50 5250-C transmission, Eaton 2 speed rear 5.57/7.60
Licensed Mechanic for: Detroit Diesel, Deutz, General Motors, Wisconsin, Continental, Generac, Briggs and Stratton, Tecumseh, and Kohler engines.
1Likes
LinkBack URL
I`m upgrading, are you? (GTX 780M...
Today, 07:12 AM in Gaming (Software and Graphics Cards)
