Quantcast Does HDMI output sound?
Results 1 to 10 of 10
  1. #1
    May 2007
    Default Does HDMI output sound?
    This is probably a dumb question, but does HDMI output sound aswell as video? I always thought HDMI only outputted video and you still needed audio cables. Whats the answer?
    Inspiron 1520--8600gt--t7500 2.2ghz
    1280x800--2gb ram--about time for an upgrade
  2. #2
    NBR Reviewer
    Jul 2007
    Default Re: Does HDMI output sound?
    Yes, it can output sound as well. I think HDMI is classified as a digital audio/video connector.
  3. #3
    APH!
    Mar 2006
    Hetalia.
    HDMI is an acronym for “High-Definition Multi-Media Interface™,” which means that both audio and video are included [the word "multi-media" should be sufficient hint].
  4. #4
    Trailblazer
    Jul 2007
    Rockville, MD
    But the presence of sound will depends of the device outputting through it capabilities.
  5. #5
    Moderately Boss
    Aug 2007
    Sydney
    HDMI can play both high quality digital video/audio. Most notebooks support digial audio
  6. #6
    Master Viking
    May 2007
    Huge Tracts of Land
    The HDMI interface indeed carries digital sound, its basically the combination of a DVI and a Optical Digital sound output into one interface. However your device in question can only have one or the other actually hooked up to and using the interface.
    IT Technician & Consultant
    Cisco CCNA/Security | CompTia A+/Net+
    YouTube: 4K Games - Vicious Computers
  7. #7
    Jun 2007
    HDMI, in the broad sense, CAN do digital video resolutions up to 1080p as well as 5.1 digital audio. Now, depending on your devices you may not have these capabilities. Most laptops with HDMI do not output audio. Many devices (Xbox360, Motorola cable boxes, etc) only output 2 channel audio over HDMI, requiring an optical or coaxial cable if you plan to use 5.1 audio.
    So the best answer to your question is read specs for anything you wish to purchase and ask questions before you buy.
  8. #8
    Master Viking
    May 2007
    Huge Tracts of Land
    Most laptops do indeed have audio on the hdmi, but most people do not know how to enable it! you have to manually turn on digital output from your audio control panel in most cases, it is not just plug and play.
  9. #9
    Feb 2008
    Great Britain
    HDMI usually carries digital audio in the S/PDIF format.
    Novatech x80r / Clevo M570RU-U - T9300 - 4GB OCZ DDR2-667 - 160GB 5400rpm WD HDD - 512MB 8800m GTX - 17" WUXGA - Intel 4965 A/G/N WiFi - Bluetooth - Vista Home Premium 32
  10. #10
    Sep 2006
    Calgary Alberta
    No S/PDIF is a different format, and more limited in both bandwidth and usually signal format type. HDMI now carries a multitude of formats both compressed and uncompressed, and as a connection type is outside of the S/PDIF spec.
    This may help people;
    http://www.hdmi.com/learningcenter/faq.aspx
    HDMI carries audio and video (although not everything supplies or receives both), DVI can carry Audio in it's additional/spare bandwidth, but it's limited to the extra bandiwdth available in the unused data pins, Display port has optional audio support, which will likely mature like HDMI over time.
    - Just my two frames worth, your drivers may vary.
    - Fujitsu N6460 / ASUS T91MT - Various Workstations @ Work - Pre-release Test Cellphones & a cottage full of 'Classic Laptops'
Copyright © 2015 vBulletin Solutions, Inc. All rights reserved.
SEO by vBSEO 3.6.1
