Quantcast help: broke the ground prong off laptop charger
Page 1 of 2 12 LastLast
Results 1 to 10 of 12
  1. #1
    Jan 2008
    surrey BC
    Default help: broke the ground prong off laptop charger
    any way as the title says i broke the ground prong off my laptop charger, im just wondering what would happen if i used it with out the ground plug as there are chargers that dont even have ground plugs, would it make any difference if its there or not
  2. #2
    NBR Janitor
    Aug 2007
    Default Re: help: broke the ground prong off laptop charger
    You can potentially shock/kill yourself by touching the computer.
    Desktop: Core i7 960, 1 TB HDD, 6 GB RAM, Radeon HD 6870
    Asus G50vt-X1: P8400, 320 GB 7200 RPM, 4 GB RAM, 9800m GS
    Asus G1s-A1 - Dead Video Card
  3. #3
    Jan 2008
    surrey BC
    now i do believe thats only if there is water or some thing like that around it or on you that that would happen. im just wondering if it can be used for a week or so till i can fix it
  4. #4
    Ex NBR member :cry:
    Apr 2007
    Considering it runs AC (alternating current) it's much closer to your heartbeat and will potentially be fatal and stop your heart.
  5. #5
    NBR Janitor
    Aug 2007
    Quote Originally Posted by doger_666 View Post
    Stick your finger into the power socket. I don't think you need water to feel a nice zap.
  6. #6
    Jan 2008
    surrey BC
    its not like i would be touching any electrical parts on it well its running plus it does not have that ground when its running on the battery and we dont die every time are laptops run on there batterys or even get shocked XD
  7. #7
    NBR Super Moderator
    Jul 2006
    NBR Moderator HQ
    Seriously...its a really bad idea to use an electrical part that is known to be broken. Stupid, too.
    Desktop   15" Macbook Pro Retina
    W7 Ultimate, Core i7 4770k, Crucial M500 240GB SSD
    16GB RAM, GTX 780, 3x Dell U2412M Surround
       Mavericks, Core i7 4750HQ, 8GB RAM
       256GB SSD, 32GB iPad Air
  8. #8
    Jan 2008
    surrey BC
    its just the ground prong, every thing else is fine, and when the laptop is running on battery it does not have that grounding prong so i dont think there would be any really bad that would happen if its missing, heck ive used tons of power cords that have the ground missing, i just dont want any thing to happen to the laptop so im just checking, from what i learned in high school it was just to protect from shock incase there is water or some thing along those lines. also all the replacement chargers im seeing dont have grounds so how is it that they dont need a ground but this one would KILL ME if i used it
    not trying to fight any thing any one is saying im just used to people giving me the facts about things not just saying dont use it you will die, just right now im having trouble getting in touch with the people i normaly talk with about this kinda stuff
    also greg nice ultra portable, was thinking about the D430 but by the time i will be able to afford that it will probley almost be time for intel to bring out the next gen CPUs (witch im hoping will use less power)
    any way i will probley fix the cord on the laptop in like a week but my buddys so going to kill me if he cant use his laptop for a week
  9. #9
    Sep 2006
    Calgary Alberta
    While it's not going to fry you in an instant unlike some of the posts suggest, Greg's statement is the general wise idea in such things, "Seriously...its a really bad idea to use an electrical part that is known to be broken.".
    Be it that it may harm you or harm your laptop, just get it fixed.
    If you have a GFCI outlet plug it into that if you must.
    - Just my two frames worth, your drivers may vary.
    - Fujitsu N6460 / ASUS T91MT - Various Workstations @ Work - Pre-release Test Cellphones & a cottage full of 'Classic Laptops'
  10. #10
    Breaks Laptops
    May 2006
    N'Awlins
    See if you can replace your 3 wire with a 2 wire adapter like on HP, Dell and some others. I still see 3 wire(AC) adapters in use which is so third world engineering. If you have a house wiring ground problem or power strip problem, you could be at risk or pick up noise when sending audio out to receivers.
    Gateway P6831FX -T9300 -512MB 8800M/GTS -3GB Ram - 2-WD250GB -Vista Home+SP2
    Asus UL30Vt-A1 Roadie + Keyboard Mod + Intel 6300AGN + Momentus XT- uVolt .9125@1906MHz
    Qosmio X775-Q7380-i5 2.4Gh/GTX 560M-192bit
    11" Clevo W110ER Game Roadie + i7-3610QM + 650M/DDR3 + Prema uVolt Bios Mod
Copyright © 2015 vBulletin Solutions, Inc. All rights reserved.
SEO by vBSEO 3.6.1
