Results 4,941 to 4,950 of 5685
Thread: The "Undervolting" Guide
5th May 2010, 04:15 PM #4941
Re: The "Undervolting" Guide
The "Undervolting" Guideis there anyway to undervolt an i720qm?
5th May 2010, 04:31 PM #4942Banned
- Join Date
- Jun 2009
- Location
- United Kingdom
- Posts
- 6,711
- Rep Power
- 0
6th May 2010, 03:12 AM #4943Notebook Consultant
- Join Date
- Feb 2010
- Posts
- 299
- Rep Power
- 9
Just curious: Undervolting on Core i processors is totally impossible, or just we've not known the way yet?
Old: Thinkpad T400. CPU P8600 undervolted from 1.1375v to 0.95v. 4GB RAM. 7200.2 Momentus 160G. 1440x900 screen on HD 3470
. Used in 20 days.
New: Thinkpad T400. T9400, yet to be undervolted, 4GB RAM, 7200 rpm hard disk, 1440x900 LED on HD 3470
6th May 2010, 03:55 PM #4944
Intel removed the VID, requested voltage, information from model specific register MSR 0x199. Because of this, in the Core i design, you can no longer request how much voltage you would like the CPU to use. There is no VID information in register 0x199 anymore so Core i CPUs don't look in there before setting the core voltage. Some older software designed for Core 2 CPUs can read data from this register and it might make you think that it is reading VID information but it isn't.
Intel says this is no longer possible and there is nothing in the publicly available documentation to show how to do this if it is still possible. If anyone discovers a way, they'll be an instant hero but so far there is no software available to do this.
7th May 2010, 06:21 PM #4945Newbie
- Join Date
- Jul 2006
- Posts
- 7
- Rep Power
- 17
hi every one,
I just bought an laptop with SL9600 CPU.
I tried to use RMCLOCK to undervolt but it seems not working.
I run RMCLOCK on windows 7. I set the SuperLFM FID 6.0x VID=0.900V
I just check only the box of this setting to be sure that I'm running the correct setting. But when I use orthos to stress CPU+RAM. I see in HWmonitor. The speed of CPU jumps to maximum speed 2.1Ghz, and the voltage runs from 0.925 to 1.025V????!!!
Even when I leave the laptop idle the voltage still is 0.925 instead of 0.900V?
So what's wrong with my work?
7th May 2010, 08:14 PM #4946
Try this vragon:
An SL9600 supports IDA mode and has a maximum multiplier of 9.0 for a total speed of 2400 MHz on one core while the second core is in the C3/C6 sleep state. This can happen automatically when set up correctly. RM Clock is not accurate at reporting IDA and it does not officially support the 45nm CPUs so there might be a few small problems but it should work OK when set up correctly.Last edited by unclewebb; 7th May 2010 at 08:20 PM.
11th May 2010, 11:26 AM #4947Newbie
- Join Date
- May 2010
- Posts
- 1
- Rep Power
- 0
Anyone know if there's a problem with AMD Athlon II M340 processors?
I can't seem to find the Advanced CPU settings tab in RMClock
11th May 2010, 01:14 PM #4948
RMClock is not updated to work with AMD 45nm CPUs from the Athlon II / Turion II family.
You could perhaps ask the developers of CPUGenie if their application supports AMD CPUs.
But its not free and only offer 30 day trial.Clevo P170HMx: Intel Core i7 2720QM | Nvidia Geforce GTX 680m 4GB | 8GB DDR3 | Intel SSD 510 120GB | Seagate Momentus XT 500 GB
Accessories: QPAD QH-1339, QPAD MK-80 & Logitech Performance MX.
My YouTube channel | 4K-Games Steam Community | Play-Connect - Monthly Giveaways
11th May 2010, 04:40 PM #4949Notebook Enthusiast
- Join Date
- May 2010
- Posts
- 35
- Rep Power
- 8
one question
will i loose the garantee ?
because the hardware can take damage of this
11th May 2010, 07:25 PM #4950
Are there any reports in this 496 page thread of people damaging their CPUs?
If you reduce the CPU voltage too much your computer might become unstable and it might crash or reboot. If it does that, give it some more voltage and try again. Pretty hard to hurt a CPU.
1Likes
LinkBack URL
I`m upgrading, are you? (GTX 780M...
Today, 07:12 AM in Gaming (Software and Graphics Cards)
