Quantcast How to fix loose USB port?
Results 1 to 5 of 5
  1. #1
    Dec 2007
    Default How to fix loose USB port?
    One of my USB ports became a little wiggly and loose after I accidentally knocked the receiver that was plugged into it. How can I fix this or tighten it back up?
  2. #2
    Aug 2007
    Default Re: How to fix loose USB port?
    open it up and start soldering
  3. #3
    Dec 2007
    What needs soldering?
  4. #4
    Banned
    Aug 2007
    Chicago, IL, 60626. Rogers Park
    Duct tape and "crazy glue", just kidding I have never done, soldering sounds correct but am surprised it still works if solders have come loose.
  5. #5
    D3X
    D3X is offline
    the robo know it all
    Nov 2005
    Toronto, Canada
    yep. Must of been the outer shroud/metal cage around the connector, this is soldered directly to a ground point and even if it's loose it doesn't affect connectivity. Ever seen those super thin USB drives that don't have the metal shroud ontop? see below:
    Unfortunately the only way to properly fix it is to solder that back onto the main board, but I wouldn't be too concerned about it.
    Apple MacBook Pro Unibody Late 2008 -> Early 2009 DIY Conversion | Core 2 Duo 2.66Ghz ▪ 8GB DDR3 1066 ▪ 9400m + 9600m GT 512mb ▪ OCZ Vertex SSD 250GB ▪ Hitachi 5K500.B 500GB DIY OptiBay ▪ MacBook Air SuperDrive Mod ▪ Snow Leopard + W7 Enterprise
