Quantcast Battery latch broke, does this affect my battery?
Results 1 to 3 of 3
  1. #1
    Feb 2007
    Default Battery latch broke, does this affect my battery?
    I've just had my Toshiba Satellite for about a year now (the warranty just expired last week which does not help me.) In a year, I noticed that I lost about an hour and a half charge of the battery, so I went to take it out to see the model number (to get a new battery) and a little black piece fell out with it. It was the right side latch that had broken off at some point, so only the left side locks. I realized a while ago I had about 2 hours of charge, but now I only have barely an hour of charge under the same circumstances (wireless off and such). Could the broken latch have caused the reduction in charge, or did it just even out. Can I fix the latch myself? I don't think gluing it will do any good obviously, I can't even get into there but I don't know if I have to purchase just a part for the latch or a whole new bottom.
  2. #2
    Notebook Prophet
    Aug 2007
    Chicago, IL
    Default Re: Battery latch broke, does this affect my battery?
    its normal for battries to lose full charge, only fix is a new one. the latch you can repair them yourself, although they are a bit tricky...
  3. #3
    May 2007
    Ottawa, Ontario, Canada
    No, it won't, as long as the connectors are touching, it will be fine.
    Toshiba Satellite A300-05U
    Intel C2D T5750 2.0GHz
    Toshiba MK-2552GSX 250Gb 5400RPM
    Intel A/B/G/N +Bluetooth
    3GB DDR2 667Mhz
    15.4" Brightview
    ATI Mobility Radeon HD 3470 256MB DDR2
Similar Threads
  1. AC power affect battery?
    By allthaticanbe in forum Dell
    Last Post: 1st August 2006, 07:55 PM
  2. Does weather/temperature affect battery life?
    By neokoros in forum What Notebook Should I Buy?
    Last Post: 10th July 2005, 06:32 PM
  3. FS550 Latch Clip Broke - help
    By mmmagination in forum Sony
    Last Post: 28th April 2005, 09:20 AM
  4. Will 7200 Hard drive affect Battery?
    By skreves in forum What Notebook Should I Buy?
    Last Post: 9th March 2005, 04:16 PM
  5. Gateway 3018GZ Battery Lock Latch???
    By Wild Urchin in forum Gateway and eMachines
    Last Post: 5th March 2005, 01:37 AM
Copyright © 2015 vBulletin Solutions, Inc. All rights reserved.
SEO by vBSEO 3.6.1
