Quantcast I need help getting my webcam to work on my HP laptop
Results 1 to 4 of 4
  1. #1
    Aug 2006
    Default I need help getting my webcam to work on my HP laptop
    I do not know how to get it to work, I tried updating the driver and it did but it does not work, and I can not find the option to use it either. My friend and I also tried a webcam talk through aim but he said he got the message that I did not have a webcam connected. O_o
    My laptop is a HP Pavilion dv2415nr.
    Any help would be so great. Thanks for reading!!
  2. #2
    Jul 2007
    UK
    Default Re: I need help getting my webcam to work on my HP laptop
  3. #3
    Jul 2007
    did you use have your OS automatically look for drivers and update on its own? Try doing a manual update yourself. head to the HP support site and find their cam drivers. Confirm that the new driver you will be installing is indeed newer by looking at the version number. If so then down and double click the setup exe.
    If that doesnt work then maybe the new drivers simply dont work. Roll back the drivers and try then.
    Did your system ship with any HP cam software. My asus for instance came with a program known as lifeframe. If HP has something similar, try seeing if your cam works in that prog.
  4. #4
    Aug 2006
    Yay!! Driver update worked. Sorry I'm really new at these things but now I know where to ask questions if I get really stuck, and I'll make sure to use the search function first.
    Thanks Guys!!
Similar Threads
  1. Can't get my webcam to work??
    By compduce in forum HP & Compaq
    Last Post: 29th July 2007, 03:53 PM
  2. Replies: 3
    Last Post: 17th June 2007, 09:46 PM
  3. how to record w/webcam and how to get mic to work
    By chadrick_r6 in forum HP & Compaq
    Last Post: 29th May 2007, 10:43 AM
  4. Microphone And webcam doesn't work
    By Semyon171 in forum HP & Compaq
    Last Post: 12th April 2007, 10:39 AM
  5. Has anyone gotten their Webcam to work with Vista?
    By Oranjoose in forum Accessories
    Last Post: 9th November 2006, 11:01 AM
