Quantcast At what point is there a noticeable difference between 2.0 ghz and 2.4 ghz?
Page 1 of 2 12 LastLast
Results 1 to 10 of 15
  1. #1
    Jul 2007
    Default At what point is there a noticeable difference between 2.0 ghz and 2.4 ghz?
    What applications, tasks, etc should one be doing to be able to notice that a 2.4 ghz is faster than a 2.0? I'm under the impression that getting a 2.4 ghz PC is unnecessary for anyone not searching for the newest prime number, making movies, or gaming. (is it even that necessary for gaming? I don't know. I don't game)
    Please shed some light on this topic, as it could save me (and others) some $$$.
  2. #2
    Feb 2007
    Default Re: At what point is there a noticeable difference between 2.0 ghz and 2.4 ghz?
    CPU speed is only part of the equation. There are other factors like bus speed, cache size, etc.
  3. #3
    Feb 2007
    Which CPUs are you looking at specifically?
    Many people prefer to start with a cheaper slower one, add a cheap (improved) cooling solution, and then just overclock it.
  4. #4
    Jul 2007
    I'm specifically talking about the Santa Rose CPUs that are out right now.
  5. #5
    Feb 2007
    The bigger cache will be somewhat noticeable for anything CPU-intensive. Everyday tasks won't see much of an improvement.
  6. #6
    Jul 2007
    Washington, DC
    Quote Originally Posted by amitface View Post
    I think you answered your own question there. The point that you need a 2.4 Ghz instead of a 2.0 Ghz is when the application you're running is CPU-bound.
    Prime number searching and gaming are both CPU-bound. Making movies is CPU-bound and/or IO-bound.
    For general desktop tasks like browsing the web, email, listing to mp3's, instant messaging, word processing, etc. You will not notice much difference at all between 2.0 and 2.4 simply because your applications don't demand it. If this is your intended use, save yourself a few $$$ and get the 2.0.
    1. Macbook Pro C2D@2.33Ghz, 4GB, 320 GB, ATI X1600, DVDRW, OSX 10.6.
    2. Toughbook CF-71 P2@366Mhz, 256MB, 40GB, DVD, Win2000
  7. #7
    Mar 2007
    Outer Space
    Couche Wouche
    Lenovo 3000 c200, 7k250 hdd, 2gb of corsair valueselect, XP sp3.
  8. #8
    Jun 2006
    Quote Originally Posted by lupin..the..3rd View Post
    Uh...Gaming's GPU bound the majority of the time...
  9. #9
    Jul 2007
    Washington, DC
    Quote Originally Posted by who8mahrice View Post
    Only at very high frame rates. You're saying that if we ran gaming benchmarks on a machine, all things being equal, the 2.0 Ghz would get the exact same FPS as the 2.4 Ghz?
  10. #10
    Moderately inquisitive
    Apr 2005
    Swindon, UK
    In theory, the 2.4GHz CPU is 20% faster than 2GHz. If you are doing something which takes tens of seconds or minutes and fully loads the CPU then it will finish sooner (eg 50 seconds instead of a minute). You will notice that if you use a stop watch, but without the stopwatch it will seem to be the same time. But if the CPU is not the bottleneck for whatever you are running then you may not measure any improvement at all. The PCMark05 benchmark, although a couple of years old, probably gives a reasonable overall indication of the difference in performance between different hardware setups. However, the summary results in reviews usually only shown the CPU / GPU and don't mention the RAM and HDD.
    John
Similar Threads
  1. Upgrading my Pentium M 730 1.6 Ghz to a 760 2.00 Ghz. Will it be worthwhile?
    By SymphonyX in forum Hardware Components and Aftermarket Upgrades
    Last Post: 17th May 2007, 02:06 PM
  2. Dell 6400 2.33 Ghz or 9400 2 Ghz with Nvidia
    By mumbaifans in forum What Notebook Should I Buy?
    Last Post: 28th December 2006, 02:16 PM
  3. Noticeable difference between 1.83 and 2.0 GHz?
    By jrgles44 in forum Apple and Mac OS X
    Last Post: 4th August 2006, 10:50 AM
  4. Centrino-1.86 Ghz (Alviso) - AMD Turion MT-34 1.8 Ghz
    By LuckyST in forum What Notebook Should I Buy?
    Last Post: 31st December 2005, 10:09 AM
  5. 1.73 Ghz Pentium M, 60GM 7200 RPM HD vs 1.86 Ghz
    By mefloquine.dream in forum Dell
    Last Post: 26th May 2005, 09:46 PM
