Results 1 to 2 of 2
Thread: Help with video problem
30th April 2012, 05:16 PM #1Newbie
- Join Date
- Apr 2012
- Posts
- 4
- Rep Power
- 0
I have a Gateway MS2252 that was recently given to me, and I'm having a bit of a problem. The screen will suddenly start displaying little white lines that flicker randomly accross the screen, then it will go black after about 15 seconds and become unresponsive. It has popped up a few times and mentioned a driver that stopped working, but I can't remember the name of it. It's definitely an nvidia driver, though. It seemed to only do this when I'm using Java, Shockwave, or Flash, though. Now, however, I just logged on and hadn't done anything and it went to the black screen. When it does this, it will turn the screen off (there is no backlighting) then back on. The screen will be black, but still backlit, and it will display only my mouse cursor, which I can move without any lag or delay. It continuously switches back and forth from having the display on to having it off, and the intervals are random.
Any idea what is causing this and if it's fixable?
30th April 2012, 05:33 PM #2Newbie
- Join Date
- Apr 2012
- Posts
- 4
- Rep Power
- 0
Re: Help with video problem
I think I solved the weird black screen problem. Now it's just the flickering and crashing. The driver in question is the nvlddmkm driver. Is there any solution to this problem? I found this thread:
Definite solution to the nvlddmkm video crash on the P-7805u!
but I'm not sure if it will work for me or not. Any suggestions?
LinkBack URL
I`m upgrading, are you? (GTX 780M...
Today, 08:53 AM in Gaming (Software and Graphics Cards)
