Quantcast found a way to GREATLY improve FPS stability with VERY LOW TEMPS 7811fx/7805u users only - Page 21
Page 21 of 23 FirstFirst ... 1117181920212223 LastLast
Results 201 to 210 of 225
  1. #201
    Feb 2009
    Next to my dead P-7805u and my new Lenovo Ideapad z580!
    Default Re: found a way to GREATLY improve FPS stability with VERY LOW TEMPS 7811fx/7805u users only
    Quote Originally Posted by Infiniteone View Post
    Unfortunately this was short lived. After about 20 min of MW2 my Video kept crashing and recovering. I did enjoy the smoother FPS though so Im going to try .95v and then 1v to see if I can find the sweet spot for my gts.
    Yea this volt mod @ the OP settings works ok for games like Wc3 TFT and the such, but with high end games like MW2 and Crysis you will get crashes as those games require max GPU load and that voltage just isn't enough.
    *Lenovo IdeaPad z580 i7 3612QM + Geforce GT 635m + 4gb ddr3 1600*
    *Out of Service P-7805u FX - X9100 *UPGRADE!* | 4GB RAM | 320GB 7200RPM | 9800M GTS OC'ed @ 720/915/1850 | Windows 7 Upgrade | LG 1920x1200
    *Check out my gameplay vids on www.youtube.com/androsforever
    Modded and Tweaked my machine for maximum performance
  2. #202
    Mar 2010
    Has anyone tried lower the voltages of the lower 3 profiles to something less than .9V? I would think that for 2D the voltages could be set really low.
  3. #203
    Team Teal
    Aug 2006
    Sharks Territory
    Mine are 0.8
  4. #204
    Jun 2008
    I have a 7811FX and I get overheating-related crashes like a lot of other people. I've tried every fix out there (including various RivaTuner shenanigans) but have only ever found partial success; this GPU undervolting is the only thing left I can try but I'm not completely confident that I fully understand the process.
    I can't use the instructions in the OP because nvflash gives a compatibility error for the 7811FX, and I can't follow zolidznake's alternate instructions on page 14 to the letter because I haven't the slightest idea of how to get a hold of a copy of my own BIOS. Forsaken123 apparently has a collection of some of zolidznake's mods over here which might let me skip to the end of that whole process, but those were made from 9C.10.00 and I'm currently running 9C.05.00, so I'm not sure if they're safe to use. I tried upgrading to 9C.10.00 myself via a win32 executable, but it insisted that I was reverting to an older version; that didn't make much sense so I panicked and canceled it.
    I've never flashed a BIOS before and I know it can brick your computer if you do it wrong, so I'm afraid to do anything without knowing for sure that it won't cause a problem. Could anybody give me a quick confirmation as to how I can safely proceed from this point?
  5. #205
    Jun 2010
    Hi, i downloaded the bios files posted by ONE J, but im facing a problem, i got a 7805u, gpu 9800m GTS (1gb) and the 7805u bios file posted by him is showing a 98000m GT instead. Should i go on with flashing? ty in advance
  6. #206
    Nov 2010
    Hi ONE_J can you send me a 9c.17.00 .95v files for the 7811? I tried so many times and all the links I've found around this forum are dead.
    My email is mrdull@hotmail.com
    Thanks.
  7. #207
    Dec 2010
    One_J, has there been a way yet to flash the VGA bios directly? I want to be able to test out my own voltages, but I don't want to bother you with bios requests. Also, I don't trust myself to not make any mistakes. I think I have seen some VGA BIOSes from this card floating around the internet, but I don't know how people got them.
    Another question, isn't NVFlash developed by NVidia? And if so, couldn't I just ask them if they have a working version?
  8. #208
    Jan 2009
    Chi, IL
    You can't adjust the voltage of the GPU:
    Undervolting/overvolting gpu impossible through nibitor
  9. #209
    Jul 2011
    Is there anyway to do this in windows vista without having a dos bootable usb drive? If so, can someone post how?
  10. #210
    Aug 2011
    ONE_J is it possible to get a copy of that bios.wph for 7811fx so I will be able to flash through nv, would be greaty appreciated my email is stillmehungry@gmail.com
    Thanks!
