Results 1 to 4 of 4
Thread: Any way to control fan speed?
20th February 2007, 12:43 AM #1Notebook Guru
- Join Date
- Aug 2006
- Posts
- 53
- Rep Power
- 17
My CPU hits 80C all the time, and my fan is never on on the side of my computer, I was hoping there was some sort of thing which could turn it on with a bit more effeciency, or one where I could just juice it to 50-100%, I have an Acer Travelmate 4670, if you need anything else to tell me what kind of program or something just ask! Thanks.
20th February 2007, 01:13 AM #2
Re: Any way to control fan speed?
The only way that you may be able to would be with Speedfan
http://www.filehippo.com/download_speedfan/
Some motherboards support it, some don't use it at your own risk.
Good Luck
20th February 2007, 07:14 PM #3Notebook Guru
- Join Date
- Aug 2006
- Posts
- 53
- Rep Power
- 17
So if that doesn't work there's nothing I can do? I mean, it's ridiculous, my CPU gets up to like 80-90C, and the fan doesn't come on, that seems like an enormous hardware flaw or something, I just wanna make sure
20th February 2007, 07:30 PM #4
I'd strongly suggest getting a cooling pad for that computer, 80 - 90*C is very hot compared to any laptops I've seen.
What CPU do you have by the way? If it's a Pentium M you can try the undervolting section of the cooling guide. There are two cooling pad reviews in there too.NotebookReview Writer & Reviewer
hp EliteBook 8740w 17" DreamColor2 1920x1200, Windows 7 Pro, Core i5-560M, ATI FirePro M7820, 8GB RAM, 120GB Intel 320 SSD, Intel 6300 WLAN
Notebook Warranty Guide | Computer Optimization Guide | SSD Upgrade Guide: How and Why
LinkBack URL
I`m upgrading, are you? (GTX 780M...
Yesterday, 02:21 PM in Gaming (Software and Graphics Cards)
