Quantcast Dell Studio XPS 1645 Problems! Need help!
Page 1 of 2 12 LastLast
Results 1 to 10 of 13
  1. #1
    Jan 2006
    Default Dell Studio XPS 1645 Problems! Need help!
    Hi guys, I got this dell studio xps 1645 at the moment.
    I've got major problem on this laptop.
    Without the charger, this laptop turns on fine.
    It goes to Windows 7, loads properly, able to do work and all and its good.
    With the charger, this laptop keeps getting the blue screen error.
    it just keeps restarting and sometimes it just shuts down by itself.
    I read somewhere that it's because it's HOT or something to do with the throtlle thingy, I don't know.
    What I wish to seek help is.
    What can I do in order to improve it's condition?
    Like, update the BIOS?
    How do you check if the adaptor is the 130 type and not the 90?
    I've been searching and havent found any solution with regards to this.
  2. #2
    Dec 2005
    Sydney, Australia
    Default Re: Dell Studio XPS 1645 Problems! Need help!
    What are the temperatures as reported by HWMonitor when plugged in?
    As for the adapter type, what is the Voltage and Amperage that is listed on the sticker of the AC adapter? (e.g. 19.5V 4.7A which is probably 90 Watt)
    Have a good one!
  3. #3
    Jan 2006
    Im using the program Core Temp 1.0 RC3 at the moment.
    It says;
    Tj. Max 100 C
    Core #0 91 C
    As for the adapter, it says
    Model: FA130PE1-00
    INPUT: 100-240V 50-60Hz 2.3A
    OUTPUT: (19.5V) 6.7A
  4. #4
    Dec 2005
    Sydney, Australia
    If the computer isn't doing much, 91C is very hot. HWMonitor should be able to give you temperatures of more components in your laptop. Perhaps you need to open up your laptop and clean it of dust etc.
    Service manual is easily available: Documentation (one of my favourite things about Dell).
    Have a good one!
  5. #5
    Jan 2006
    Did that already.
    Update:
    Also, the CPU usage is at 100%
    It's ridiculous.
    I've read somewhere that it's about the throtlling issue thingy?
    There was a discussion here somewhere about that but it was back
    in 2011. All the download links are down.
    For example, this thread;
    S-XPS 1645 Throttling Info. and Updates
    Btw, do I have a 90W or a 130W power supply?
  6. #6
    Aug 2012
    Braintree,ma
    Quote Originally Posted by Stalvros View Post
    Did that already.
    Update:
    It's ridiculous.
    You need to read the tag on the adapter to know what wattage the adapter is
  7. #7
    Jan 2006
    ImageShack® - Online Photo and Video Hosting
    didnt say anything about 90W or 130W
    The only thing it says about 130 is the model I guess.
    But I can't be sure.
  8. #8
    Jan 2006
    I've got plenty of problems with this laptop now.
    I just switched it on again, it loads to windows,
    and right now it doesnt detect any drivers.
    My sound driver is gone
    Cannot load windows aero theme
    cannot connect to internet
  9. #9
    Aug 2012
    Braintree,ma
    Simple ohm's law answers your question. voltage x amperage = wattage(19.5x6.7=130.65)
    Now in the future you know how to figure it out
  10. #10
    Jan 2006
    So I've got 130W at the moment.
    I've already updated my bios to the latest A07.
    And i'm still having lots of problems with this laptop.
    Any suggestions?
Similar Threads
  1. Replies: 1957
    Last Post: 28th August 2014, 02:49 AM
  2. Replies: 2
    Last Post: 12th September 2012, 02:32 AM
  3. Dell Studio XPS 1645 heat exhaust mod, throttling
    By vidar808 in forum Dell XPS and Studio XPS
    Last Post: 15th October 2010, 05:26 PM
  4. Studio XPS 1645: random crash problem
    By RyGuye45 in forum Dell XPS and Studio XPS
    Last Post: 12th August 2010, 08:12 AM
  5. Dell Studio XPS 1645 RGBLED problems
    By Beconsiderate in forum Dell XPS and Studio XPS
    Last Post: 19th December 2009, 04:29 AM
Copyright © 2015 vBulletin Solutions, Inc. All rights reserved.
SEO by vBSEO 3.6.1
