Quantcast Possible Unique Sound Problem with Dell Studio XPS 16 (1640)
Page 1 of 4 1234 LastLast
Results 1 to 10 of 35
  1. #1
    Jan 2008
    Angry Possible Unique Sound Problem with Dell Studio XPS 16 (1640)
    Long story short:
    My sound does not play through my on-board speakers, but does play through external speakers or headphones. It is not a hardware issue, as I can replicate a way to make sound play through the on-board speakers temporarily, but I cannot figure out a permanent solution without doing a fresh install, and I'd rather not resort to that.
    Long story:
    About a month ago, my original hard drive failed. I was able to request a replacement hard drive under my warranty, which came with a self-installing image of Vista (and other Dell software). I was using Windows 7 beta on my old hard drive and decided to go with the release candidate for my new one. I bring this up because it seems I made a mistake in upgrading from Vista to Windows 7, instead of just using a clean install. On my old hard drive, I did a clean install of the beta and had to do some tinkering to make it all work, so I was hoping I wouldn't have any issues with drivers by just upgrading then removing the excess bloatware.
    Well, everything seemed to go according to plan. I installed a bunch of programs, copied a lot of stuff from an old PC, and didn't suspect anything until, one day, I didn't have my external speaker jack plugged in. I wasn't hearing any sound, but knew that my on-board speakers should at least be working. I first thought I may have disconnected something when installing the hard drive somehow, but the hardware checked out just fine. I uninstalled, reinstalled, upgraded and did a number on my drivers, but nothing seemed to work.
    I know that it is not a hardware issue, because I can replicate a way to make sound play through the on-board speakers temporarily. If I open up the sound options from the control panel and "test" both of the enabled devices while listening to music, my on-board speakers will temporarily play whatever music I'm listening to, and my external speakers will play the test sounds. It seems to be a weird issue where all sound is being directed externally, unless a test in progress, then the sounds that are already playing will be projected by the on-board speakers. To make it simple: the on-board speakers work if I run a test while listening to music, but only for the duration of the test (3 seconds), then the problem returns.
    As of now, everything is exactly how I want it to be on my machine, and I don't want to have to do a fresh install just to fix this minor-yet-annoying issue.
    Relevant information:
    OS: Windows 7 Release Candidate 1
    Drivers on Device Manager:
    ATI High Definition Audio Device
    IDT High Definition Audio CODEC
    (tried all of the latest IDT drivers, also tried Windows automatic drivers)
    Sound Devices from Control Panel:
    "Speakers / Headphones" enabled as Default Device
    "Independent Headphones" enabled as Default Communication Device
    (I have tried switching their roles, enabling, disabling and testing them all)
    Any information would be greatly appreciated.
  2. #2
    Jan 2008
    Default Re: Possible Unique Sound Problem with Dell Studio XPS 16 (1640)
    Bumping this for the weekend.
    Here's to hoping that someone may have already run into a similar problem and found a solution. *crosses fingers*
    Thanks in advance.
  3. #3
    Lost in the MYST
    Oct 2008
    just back up everything and reinstall os and get it back the way you like it is it really that big of a deal
    Alienware M17xR2
    Core i7 920XM | 256GB Samsung SSD + 500 GB Seagate Momentus | 17" 102% Wide Gamut 1920 x 1200 RGBLED | Blu-ray Burner | ATI Mobility Radeon 5870 x2 | 8GB DDR3@1333MHZ | Bigfoot Killer Wireless -N 1103 | Soundblaster X-FI Surround 5.1 Pro + TB HPA2 True 5.1 Headset w/ TB Z6a In line amp
  4. #4
    Jan 2008
    Quote Originally Posted by Mkelliny View Post
    Yes, it really is that big of a deal, or I wouldn't have asked.
    The process of recovering my old files, transferring files from my old disassembled computer, and then installing and updating all my software was a very tedious process; I don't wish to repeat it unless I have to. I have no means of easily backing up my data (at least 250 gigs), and I don't want to fork over money for an external hard drive at the moment, so that's a last resort for me.
    I'm hoping for someone that may understand this computer better than me to lead me in the right direction for a possible solution, without resorting to the typical PEBKAC responses.
  5. #5
    Sep 2009
    Do you mean your laptop speakers play no sound at all but when you click the Test in Sound Devices, it will play the ding ding ding sound ?
    Studio XPS 1640 : Status : [||||||] -Dead Screen
  6. #6
    Jan 2008
    Quote Originally Posted by chewyeong90 View Post
    Pretty much, except slightly opposite. If I'm playing music or a game with sound already, and I perform the test, the sound already playing will play through my on-board speakers, while the test sounds will play through whatever external device is attached. So, let's say, If I'm listening to a song and I run the test, the song will play through the on-board speakers and the test noises will play through my external speakers.
    I can replicate this every time by opening the Sound panel and going to my playback devices. The devices are listed as "Speakers / Headphones" (default device) and "Independent (R.T.C.) Headphones." My default device shows the sound being recognized while it plays, and the second device shows nothing. If I run a sound test from the secondary device, the above phenomenon occurs. If I run a sound test from the default device, the test sounds play through the same external speakers as the music, and nothing comes from the on-board speakers.
    I'll admit, it's very odd. I've tried uninstalling, disabling, reinstalling, updating, and downgrading all sorts of driver combinations, but I never get them to work. I'm sure it's something very simple, but I just don't know how to make it work.
  7. #7
    Sep 2009
    I still couldn't get the exact problem of yours. So in conclusion, your on-board speakers on themselves are not working, but when you plug in the external speakers, and you run the test, your on-board speakers work ?
  8. #8
    Oct 2009
    If you think your problem could be solved by re-installing your SO. You can re-install windows 7 and when installing it will ask if you want to back up your documents to C:\Windows.old
  9. #9
    Jan 2008
    Yes, you are correct. The on-board speakers will play sound only during the testing process. However, as the test only lasts for about 3 seconds, the sound only plays from the on-board speakers for the duration of the test. So for 3 seconds, I can hear audio perfectly out of my on-board speakers, then it goes back to being stubborn. This is an infinitely repeatable process.
    Quote Originally Posted by m1n05_4 View Post
    I'm considering this as an option if I can't manage to find a solution with this thread.
  10. #10
    Sep 2007
    long answer short, RC1 was not perfect. RC1 had the same issues on my asus. You're running a pre-release OS, and if you do a clean install of RTM you'll probably be fine like i was.. Might need different drivers.
Copyright © 2015 vBulletin Solutions, Inc. All rights reserved.
SEO by vBSEO 3.6.1
