Results 1 to 8 of 8
Thread: Need battery self charger?
20th June 2012, 04:29 PM #1
I did get a new power adapter and a new generic version battery for my netbook but the netbook still doesn't want to charge. It basicly shows that the battery is in use the whole time even the power cord is plugged in. I was wondering about this but is there a self charger that can charge the battery so I don't need the netbook to charge the battery? Kinda like a normal battery charger. Or what do you guys think I should do? What do you guys think the problem is?
At first I thought it was the power adapter since the voltage and watts were less than what the netbook needs since it was from a different computer but even when I got the right power adapter it still doesn't work. Basicly I got this netbook used the the owner didn't have the original power adapter. Basicly the adapter I had originaly had less power than the Dell netbook original had. I have a Dell Latitude 2100.Sony VPCEB3QFX/WI
Intel® Core™ i3 - 370M (2.40GHz)
8 GB DDR3/1066MHz
320 GB 5400rpm, Serial ATA
Realtek® High Definition Audio
Intel® HD graphics, 1.76GB VRAM
TSSTcorp CDDVDW TS-L633C
Windows® 7 Home Premium 64-bit SP1
20th June 2012, 09:54 PM #2
Re: Need battery self charger?
Check if the ac adaptor is reconized in the BIOS properly
If not your battery may not charge properly
You have to get the proper ac adaptor for your laptopM4700 I7-3720QM, 20GB, 2 x 512GB Raid SSD 256GB msata SSD Killer 1103 Wifi, K2000M
Desktop Water Cooled I7 2600K, MSI Z77A-GD65, 16GB DDR3, 2x OCZ 480GB SSD Raid 0, 3TB Raid 0 WD30EFRX Red Drives, Dell 3007, BD-R, EVGA GTX 690 Classified HYDRO Copper FTW.
My Dells Too many but presently, Inspiron 15R,, XPS L501x, 15z, Studio 15, Inspiron 6400, & M101z, m4600, m6400
20th June 2012, 11:22 PM #3
The new AC adapter I have is the OEM original kind.
I tried wiggling the tip of the cable where is connects to the netbook nothing happenes meaning it's still the same. Also when I have it plugged in the battery says 32% and has 1421 hours and 49 min left. I think it's saying that since it things the battery is in use and really it isn't so it's showing false info. Basicly acting like it's using batteries but since it's not it has soo many hours left in just 32%. But it is using the AC adapter to power the computer.
Also when I disconnect the AC adapter then the battery reads like normaly meaning like 1 or 2 hours left when it's on the desktop idle.
Also for this Dell netbook I have to have the battery installed in order to turn it on since without the battery it won't even power on. My Sony laptop can work without the battery installed but this Dell for somereaon needs it. I think there is a latch or something that has to be pushed so the netbook knows the battery is installed.Sony VPCEB3QFX/WI
8 GB DDR3/1066MHz
21st June 2012, 07:46 PM #4
Turn on your laptop, and press F2 or DEL key to get into the BIOS menu.
Check the status of the AC Adaptor - it should identify the adaptor as a Dell xx Watt adaptor
It should also identify the battery in the BIOS as well.
if the adaptor is good, and the batteries are new it really only leaves either the DC plug on the motherboard or some other issue on the motherboard as the most likely culprits.M4700 I7-3720QM, 20GB, 2 x 512GB Raid SSD 256GB msata SSD Killer 1103 Wifi, K2000M
21st June 2012, 11:12 PM #5
I did look on the internet and found someone posted about battery not charing on a Dell laptop and someone said this.
"While it may be a 'common fault', are you sure that the supply you are
using is a genuine Dell supply? I only ask because other companies sell
a supply that looks very much like the Dell original, uses the same
input and output cords and even has a representation of the Dell logo
molded into the face....but is NOT a Dell supply, and will NOT charge my
Dell laptops.
*It will run them, but not charge the battery.*
Closer examination reveals that it's really not much like a genuine
supply. It's much lighter in weight. The quality of the cabling is
markedly inferior. It doesn't have the rubber cable retainer strap.
There is no Dell information on the info sticker. It says at the top,
'Replacement AC Adaptor' and gives a few specs. At the bottom it says
'Made in China'.
I got it with a Dell laptop from Craigslist. The original owner
complained the battery wouldn't charge. Connection to a genuine Dell
supply fixed that problem."
I wounder if I' am having this problem since I got my adapter from Ebay and it could be a adapter that is like the Dell but it's not. But is this info true that if it's not a real Dell adapter it would not work?Sony VPCEB3QFX/WI
8 GB DDR3/1066MHz
22nd June 2012, 11:05 AM #6
ift is definitely possible as i mentioned above if you do not have the proper adaptor the battery will not charge
if the BIOS cannot identify the adaptor is disbales charging, and can put the laptop in low power mode (Runs Slower)
so get the peoper adaptor for your model, but from a USA based seller and ask them id it is an OEM adaptor before buying it.M4700 I7-3720QM, 20GB, 2 x 512GB Raid SSD 256GB msata SSD Killer 1103 Wifi, K2000M
23rd June 2012, 12:41 AM #7
Well I did e-mail that person and asked and he said this.
Hello dustinbroke, I am so sorry that your adapters isn't working with your netbook. I can assure you that this adapter is Genuine OEM Dell. You can go on the Dell website and see that it is. On the adapter itself it says Dell Inc with a Dell Part Number. You may have ordered the wrong adapter or the adapter might be defective. If you don't mind me asking, what type of netbook do you have? I would love to research it myself and try and solve this issue we have at hand. If you still want me to refund you that is fine also, just let me know. I can send you a return shipping label for this item if that's what you decide to do. Please let me know what you want to do ASAP so I can send you a new adapter for your netbook and get it shipped today. Thanks,
I did also ask him about another adapter that is OEM and seems like the right one for my model and he said he had that one so he send a different one the Dell PA12 adapter. The one I had apprently was not the right one for my model or something. I hope this one will work if not I might have to get a Dell battery again and not generic one if it doesn't work since I never tried using the Dell one on the right adapter. Probley next week it will come since he send it today using USPS Priority mail.Sony VPCEB3QFX/WI
8 GB DDR3/1066MHz
23rd June 2012, 10:29 AM #8
it shold be fine once you have a proper Dell adaptor
There are many knock off adaptors on ebay - you have to do some careful research of the sellers and ask questions to help ensure you get the genuine part.M4700 I7-3720QM, 20GB, 2 x 512GB Raid SSD 256GB msata SSD Killer 1103 Wifi, K2000M
LinkBack URL
I`m upgrading, are you? (GTX 780M...
Today, 05:42 PM in Gaming (Software and Graphics Cards)
