Quantcast Inspiron with SRS Premium Sound problem
Results 1 to 7 of 7
  1. #1
    Jun 2011
    Default Inspiron with SRS Premium Sound problem
    Dear all,
    I recently purchased a Dell Inspiron N5010 refurbished from Dell (Win 7 64bit home) and it came with SRS Premium Sound. The trouble is that the sound gets "scratchy" after the laptop has been booted for a while. It is fine after a nice fresh boot.
    The sound out of both the speakers and the headphone jack is affected, which makes me think it is a driver problem. I'm using the latest driver which shows up as IDT High Definition Audio Codec in the control panel.
    Has anyone else had and solved this problem? Or does anyone have any ideas on how to troubleshoot?
    Thanks in advance...
  2. #2
    such bacon. wow
    Oct 2010
    Rockville, MD
    Default Re: Inspiron with SRS Premium Sound problem
    Did you use Dell or Windows 7 audio drivers?
    Sager NP8170 (Gaming DTR): i7-2670QM|12GB DDR3|Radeon 6990M|500 GB 7200RPM (Looking for an SSD)|17.3" 1080p|7Ultimate
    Normal laptops R61: T8300|4GB|X3100|X25-M G2 80GB SSD|14" WXGA|7Pro/E6410: i3-330M|4GB|Intel HD Graphics|X25-M G1 80GB SSD|14" WXGA|7Pro
    Dell Latitude E6430 (FDA work laptop): i5-3210M|4GB DDR3|Nvidia Quadro NVS5200M/Intel HD 4000|WD Scorpio Black 320GB|14" 720p LCD|7Enterprise|Lenovo ThinkVision L2251p & D221 WSXGA+
    Other Toys: iPhone 5 White|AT&T BlackBerry Bold 9900 (work)|2014 Subaru XV Crosstrek Premium 2.0i CVT|2nd gen Google Nexus 7 16 GB|Latitude 13 Review|Dual Lenovo X220 Tablet review!
  3. #3
    Jun 2011
    I used the Dell drivers. The current ones on Dell's download page are the same as the ones that Dell shipped.
    I just tried rebooting again and the sound is fine after a fresh boot. I'm looking for what application might stomp on the driver.
  4. #4
    such bacon. wow
    Oct 2010
    Rockville, MD
    Can you record a video of the sound?
    Maybe you can disable programs one by one until you've figured it out? Also there is an off chance your speakers could be defective. Reinstalling the OS will rule out software (fresh start) vs an actual hardware issue.
  5. #5
    Jun 2011
    Of course now that I post about it, it isn't doing it any more.... http://forum.notebookreview.com/imag...s/confused.gif
    If it starts again I'll see if I can record it.
    Thanks for replying!
  6. #6
    Banned
    May 2011
    u dl this driver? Dell - Support
    it should come with defaults driver.. non of it is new version..
    bro.. do u have fan problem or any heat issue for ur N5010? thanks
  7. #7
    Jun 2011
    Thanks, that is a later version so I'll try it.
    I haven't had trouble with the fan or heat on this computer. The fan could be quieter but it's not on very much.
    Later...
SEO by vBSEO 3.6.1
