Quantcast ASUS G73, bios help, flashing help, bricked laptop help, crisis recovery help
Page 1 of 2 12 LastLast
Results 1 to 10 of 12
  1. #1
    Mar 2011
    Default ASUS G73, bios help, flashing help, bricked laptop help, crisis recovery help
    HI,
    I have an Asus G73 Jh best buy model, out of warranty.
    I was on bios 209.
    downloaded the 213 official bios.
    transferred it to Usb flash drive formatted with fat 32
    booted into bios, EZ flash.
    EZ flash could not see the files. so i cancelled
    still in bios i changed the asus fancy start setting.
    then selected " save and exit"
    Since then the problem starts.
    When i push the power button:
    1. all the blue lights , light up i.e power, twinturbo, splendid, stealth, capslock, numlock.
    2. fans spin up
    3. charger light, power light, light up
    4. HDD spin up
    5. No beep, no bios POSt, nothing on the screen.
    Things I've tried so far:
    1. Taken out battery, adapter cord, pushed the power button for 45 sec. no luck
    2. taken out ram, hdd..........No luck
    3. Cmos reset button on the base of the laptop......no luck
    WHat should I do?????????????? HEEEEEEEEEEEEEEEEEEEEEEElp please.
    any suggestions? or I'm just left with a paper weight
    I've heard about the crisis recovery mode and blind flash.. what are these?
  2. #2
    Sep 2008
    Default Re: ASUS G73, bios help, flashing help, bricked laptop help, crisis recovery help
    From what you've said you haven't actually flashed the BIOS.
    All you changed seems to be the fancy start settings.
    Therefore you should be able to remove the CMOS battery while the computer is unplugged and without the main battery. Put it back after 10+ seconds and hopefully your G73 will boot again with default settings.
  3. #3
    Mar 2011
    wouldn't the CMOS Reset button at the base of laptop perform the same function?
  4. #4
    Sep 2008
    It is not guaranteed that the reset hole will actually reset the settings.
  5. #5
    Mar 2011
    any easy way besides disassembling whole of the laptop?
  6. #6
    Sep 2008
    Not that I know of, it's in a very inconvenient location. It's located on the underside of the motherboard.
    Asus G73 Series Disassembly Guide
    You can see it in the last two pics on this page here, it's the small silver circle on the left:
    Spoiler :
  7. #7
    Mar 2011
    US
    you could RMA it. Technically not your fault BIOS flash didn't work... its pretty much Asus's for having faulty parts in BIOS. Don't try to disaassemble it. Its really tough even if your'e technically sound.
  8. #8
    Sep 2010
    Asusrog, I've had this problem when switch on fancy start.
    Just remove your two HHD, like this you should have access to Bios typing F2.
    M18x i7 2630qm, CFX Hd6970m
  9. #9
    Mar 2011
    i've tried removing hdd but it didn't work
  10. #10
    Aug 2010
    Youll have to RMA it, this happened to me.
    Boot problem after enabling fancystart
    w/ i7 840qm 1.87-3.2ghz OC 2.23~3.6ghz/8gb DDR3-1333/ATI Radeon HD 5870m OC 870/1150 UC 70/100
    Intel 6200 N/BD Combo Drive/Sandisk EXTREME 120gb SATA III SSD + 500gb Seagate 7200rpm/1920x1080 FHD LED
