Quantcast My M18X wont power on, is under warranty and Alienware won’t help me.
Results 1 to 6 of 6
Like Tree5Likes
  • 2 Post By jywang
  • 2 Post By Alienware-Luis_Pardo
  • 1 Post By TheBluePill
Thread: My M18X wont power on, is under warranty and Alienware won’t help me.
  1. #1
    Notebook Nobel Laureate
    Feb 2012
    Default My M18X wont power on, is under warranty and Alienware won’t help me.
    Does anyone have a better contact number with someone that can actually do something at Alienware Support? I bought an outlet model and apparently the service tag was registered to someone else. I have 166 Days of warranty and phone support wont help me.
    I was using the machine this morning and it just powered off hard. Won’t turn on at all. With or without battery. (Battery shows as full). Frustrating as hell.
  2. #2
    Jun 2007
    Default
    So you bought direct from outlet store and Dell thinks you are not the owner? Can you correct this by showing your receipt?
    Asus Eee Slate EP121 | i5-470UM | 64GB SSD | 4GB
    M18xR2 | i7-3820QM | 2x AMD 7970M | 12GB | 240GB Wildfire SSD (Win7) + 500GB Momentus XT + 120GB OCZ Nocti mSata (Win8) | Bluray | Killer 1103
    M17xR4 | i7-3820QM | 7970M | 16GB | 120GB SSD + 500GB Momentus Xt | Bluray | Killer 1103
  3. #3
    Aug 2007
    Sacramento
    Default Re: My M18X wont power on, is under warranty and Alienware won’t help me.
    Quote Originally Posted by jywang View Post
    yea if you are indeed the owner then you shouldn't have an issue at all.. now could there have been a mistake?? sure its a possibility.. but a recipe should clear all that up.. and Dont say you dont have one..
    If you bought it from the outlet there is ether a CC record of it or you went thru Dell financial and in which case there is a record also..
    Did you buy it from some one? and forget to transfer the warranty?
    Good luck!
    m18x-R2 3920xm / 750 momentus xt /2 x intell SSD 520 series 240gb raid 0/ Dual Dell 680m / 16gb moemory/ BD/DVD r/w
  4. #4
    Company Representative
    May 2012
    Send us an email at AWsocialmedia@dell.com with your receipt attached and I'll take care of it
    Please include your service tag, phone number and a link to this thread, that way once the warranty is fixed I'll set up a callback for the power issue
    Luis Pardo
    Dell | Alienware Technical Support Alienware Arena
    Opening your case and/or replacing parts yourself does not void your warranty, check our disassemble videos on YouTube
    Quickest way to get support from Dell: Twitter via @AlienwareTech or Facebook.com/Alienware using the "message" link.
    I can't always reply to PM's, please for extra assistance use any of the Facebook and Twitter links
  5. #5
    Feb 2012
    Just a follow up. I called back (4th call) and they were able to straiten out the warranty transfer.
    The Power Brick and Battery were "bad" according to the tech they dispatched. After replacing both, i was back in business.
    Not the greatest experience with all of the warranty run-around, but they did get me back up and running, so im satisfied.
    Thanks for all of the responses.
  6. #6
    Aug 2007
    Sacramento
    Awesome! Good to hear! Dell/alienware has the best warranty i know of! Good job alienware and awesome job reps helping him!
