Results 11 to 20 of 26
10th July 2012, 08:30 PM #11
Re: M18x R2 Connection Issues with Killer wireless 1103 NEED HELP!
For arguments sake yank out a card from one of your other machines and see if you can connect with that card installed because it could be a software issue somewhere vs hardware .
11th July 2012, 03:55 PM #12
its hardware took the network card from my gf m18 and put it on mine deleted all drivers for killer and installed intel ones and it worked tried that on hers and did the exact same thing with killer being installed on hers so leaves me to believe hardware and not software....unless im doing something completely wrong
(GAMING RIG)NXZT Phantom Full tower ,BenQ 2420TX 3D monitor, Intel 3960X I7@4.8,Classified GTX 680 4gb SLI 2way,16GB Corsair 2133,256GB Crucial X2 Raid 0,1TB Scorpio Black
(SECONDARY)Sager np8180 18.4 inch i7-2760QM,12GB RAM 500GB x2 raid 0 Radeon Crossfire 6990m
(SCHOOL)AW M14XR2 14.inch I7-3610QM,8GB RAM,900p, 750GB, 120GB mSATA ssd, NVIDIA GT650M
(GF) AW M18x R2 18.4 inch I7-3720QM3.8ghz all 4 cores,16GB RAM 750GB Radeon Crossfire 7990m 3 years
(SOLD)M15X GTX560m, (GF)HP Envy 17,M18X R2 7970
11th July 2012, 04:02 PM #13
than the problem is the card, call dell tech support.
M18x space Black| 2760QM|Kingston HyperX 16GB DDR3 1866
|GTX 580SLIM|Ocz Vertex 4 256GB
intel 520 240GB|Killer Wireless-N 1103|Internal WirelessHD|Logitech G700|Bose Companion®5|Orion M18x Backpack|Notepal U3|Logitech G510|Wave® music system III with Bluetooth® music adapter | Dell UltraSharp U2711 27|Iphone4s|Ipad Mini 64GB|
11th July 2012, 07:32 PM #14Notebook Consultant
- Join Date
- Jan 2010
- Posts
- 169
- Rep Power
- 9
I actually had the very same issue with my R1 although I have a regular wireless card. I had no Internet for two weeks and dell support said without a doubt it was the service provider not the hardware. What fixed my issue was we completely reset the router and created a new SSID and password, it's been good ever since.
Alienware M18x - 500GB 7200RPM/500GB 7200RPM SSHB HDD RAID 0 - Core i7 2960XM - Dual NVIDIA GTX 580M SLI Enabled - 8GB RAM
11th July 2012, 11:11 PM #15
talked to dell today and they are sending me a new card and i am going to install it myself. i swapped out my killer card and it didnt work in my gf m18x or my m14x but the intel card worked perfect on my m18x. Luckily it was easy to do now i just have to wait until it comes in so i can swap it out and hopes it works.
11th July 2012, 11:30 PM #16
Glad to hear you got it worked out! The boards being glitched out meant I couldn't open this page all yesterday!
Laptop Gaming
M18X R2, 3610QM, XFire 7970m, - Upgraded by me: 16 GB Corsair CL9, Crucial M4 512 x2 RAID 0, Seagate 1TB backup, Killer 1103, Plantronics GameCon 780 7.1 Headset
Desktop Gaming
Enermax Fulmo GT case, Asrock Extreme 6, i7 3930K stock w/ H80, 64GB Corsair DDR3 1600, (2) EVGA GTX 670 4GB Superclocked and an EVGA GT 650 PhysX w/ Asus 27" 3D monitor w/ Nvidia 3D Vision 2, (2) OCZ Agility 3 240GB in RAID 0, (4) Hitachi 3TB in RAID 5, MaxRevo 1350W, Sony 1000W 5.1
12th July 2012, 02:40 AM #17
yea it was like that all threw out all the forum thx for all of your advise guys. Ill let you know how everything turns out when i get the part in.
14th July 2012, 12:05 AM #18
So got did a fresh window install installed the new killer card that they sent me and still does not work now i know 2 cards cant be bad i tried the driver software from dell and on the cd that came with laptop but still same issue... So idk what to do i really like the m18x even though i havent done anything with it i use my gf 1 and its a fantastic machine to use but if i cant get it to work by monday im going to return it for refund. I had my friend look at it and he pretty much did the same thing i did and he has more experience building and fixing computers.
Now could it be that one of the wires that connects to the wifi card is disrupting the whole thing since the intel 2230 works on my m18?
Now i do connect to my wifi network i put in correct password and i can see my network out of the 4 that show. Now when i am connected it shows it as unidentified network and list it as limited connection. When i do diagnostic on my computer now its showing the default getaway is not available which idk what it means....wasnt showing this before
any help would be much appreciated.(GAMING RIG)NXZT Phantom Full tower ,BenQ 2420TX 3D monitor, Intel 3960X I7@4.8,Classified GTX 680 4gb SLI 2way,16GB Corsair 2133,256GB Crucial X2 Raid 0,1TB Scorpio Black
14th July 2012, 10:54 PM #19Notebook Consultant
- Join Date
- Jan 2010
- Posts
- 169
- Rep Power
- 9
Reread my post above. I had the same issue. Try my resolution.
14th July 2012, 11:44 PM #20Notebook Enthusiast
- Join Date
- Dec 2009
- Posts
- 44
- Rep Power
- 9
You could try the Atheros driver (BigFoot 1103 = Atheros AR938X)
Atheros & Zidas drivers
Version 10.0.0.55 WHQL (might help)
LinkBack URL
I`m upgrading, are you? (GTX 780M...
Today, 01:47 AM in Gaming (Software and Graphics Cards)
