Results 1 to 10 of 11
27th May 2012, 03:41 AM #1Notebook Consultant
- Join Date
- Jan 2010
- Posts
- 169
- Rep Power
- 9
M18x Wireless/Ethernet Connection Issue
Just finished a clean install earlier today and everything was perfect. Around 6pm last night Internet connection went out. I figured it was the modem since it tends to go out occasionally. I realized that all the other appliances that connect to the same network worked fine. I reset modem and router, no luck! Ipconfig /all shows no media connection on all listings and device manager says everything's good. Any help would be appreciated!
Edit: Dell tech support claims its an issue with the ISP and not hardware related which is good, however I can't call them cuz it's not my Internet so I have to accept no Internet for a while.Last edited by Klihne; 27th May 2012 at 04:08 PM.
Alienware M18x - 500GB 7200RPM/500GB 7200RPM SSHB HDD RAID 0 - Core i7 2960XM - Dual NVIDIA GTX 580M SLI Enabled - 8GB RAM
27th May 2012, 07:19 PM #2
Re: M18x Wireless/Ethernet Connection Issue
So with either ethernet or wireless you have no connection?
If it's both,It might have defaulted the connection to public, do you remember what you selected when you first connected it? needs to be home! (you might have done this but has court me a few times so just checking)
27th May 2012, 09:16 PM #3Notebook Consultant
- Join Date
- Jan 2010
- Posts
- 169
- Rep Power
- 9
Yes it is both and I believe I had set it to home. How do I change this if it's not?
27th May 2012, 09:40 PM #4
go to the following location
Control Panel\All Control Panel Items\Network and Sharing Center
in there it will have View your active networks
it will have your network name and below that it should have a picture of a house
if it doesn't, select the picture, could be a bench or a building meaning either public or work, and then it let's you choose, choose the house
27th May 2012, 09:46 PM #5
27th May 2012, 11:25 PM #6Notebook Consultant
- Join Date
- Jan 2010
- Posts
- 169
- Rep Power
- 9
28th May 2012, 12:05 AM #7
28th May 2012, 12:56 AM #8Notebook Consultant
- Join Date
- Jan 2010
- Posts
- 169
- Rep Power
- 9
It didn't. But called service provider and they reset the connections and everything works now!
28th May 2012, 01:00 AM #9
28th May 2012, 12:48 PM #10Notebook Consultant
- Join Date
- Jan 2010
- Posts
- 169
- Rep Power
- 9
Actually spoke too soon. 30 minutes after posting that Internet was gone again. My laptop was the only machine not connecting again
LinkBack URL
I`m upgrading, are you? (GTX 780M...
Today, 06:53 PM in Gaming (Software and Graphics Cards)
