Results 1 to 10 of 365
3rd December 2011, 01:18 AM #1
[*Unresolved* Issue] Alienware M18x: GTX 580M SLI DPC Latency Problems
UPDATE 02/21/2012: Please install Verde 295.73 drivers and implement the tweak posted here or here.
It is a rude awakening for anyone to discover that their Alienware flagship M18x beast is unsuitable for performing a task as ordinary as handling real time audio because of an unresolved driver bug. It's unfortunate that something correctable like this continues to be the Achilles heel of an otherwise incredible machine.
This thread was started for discussion of the DPC latency problem the M18x exhibits with GTX 580M SLI. I moved a number of my own posts into this thread to consolidate the information for Dell's benefit. Those are consolidated in the post below. If you're not familiar with DPC latency first hand, you don't want to be. You can read about it here. For me, this will usually manifest itself as strange clicks and pops in audio, and might be what causes what I like to refer to as the "cyborg" electronic distortion type of sound. I seem to get that randomly while gaming and sound sometimes ends up looping followed by a system freeze that coincides with that audio glitch. It does not happen all the time, but it happens enough that I don't forget about it.
It appears this issue does not affect systems equipped with AMD 6990M CrossFire. Additionally, DPC latency does not appear to be a problem running Dell's recommended driver (269.03).
Using Dell's NVIDIA 269.03 driver is OK with me for the moment, but it is starting to get a little long in the tooth and we cannot keep using it forever. We need to know what is causing it and how to fix it. Is it something Dell tweaked to correct the problem with their 269.03 driver, or is the DPC latency being caused by something NVIDIA changed in drivers released following version 269.03? Hopefully, Dell/Alienware can shed some light on this for us and produce a solution. If the reason is not known at the present time, then we can include this as an agenda item on the next conference call.
Here's where the assistance of the Alienware M18x Community is needed...
Before we can expect a fix, it needs to be established that an issue exists that needs to be fixed. If you own an M18x with GTX 580M SLI, please download LatencyMon from the Resplendence web site, run the test for 3 to 5 minutes and see if your test results are similar to mine. Please post your results and specify what driver you have installed.
When posting screen shots, please be mindful of forum rules. Images that are too large will be removed, and posts that don't make any sense without the image to reference will be deleted. Please use thumbnails or spoilers, upload the image as an attachment, or resize the image.
Thanks in advance for your testing and reporting.Alienware M18x R1 v2.0 | Intel Core i7 3920XM @ 4.8GHz | NVIDIA GTX 680M SLI
16GB Kingston HyperX DDR3 2133 | Panasonic UJ235A eSATAp BluRay Rewritable
480GB OCZ Agility 3 SSD RAID0 - Windows 8 | 128GB Crucial M4 SSD - Linux Mint
120GB Altas mSATA SSD | Cache-Accelerated 1TB Seagate Momentus LP HDD
Mr. Fox's Benchmark Results: [LINK] | Custom Yellow PearlAlienware M17x R2 | Inspiron M5030 | Inspiron Mini 9
Need help? Please look here before posting: LINK
19th December 2011, 09:03 PM #2
M18x GTX 580M DPC Latency Problems using Dell beta and NVIDIA Reference Drivers
I ran through a series of tests and the GTX 580M SLI setup has zero problems with DPC latency while using the Dell 269.03 display driver. The image below is at system idle when using the Dell 269.03 driver. I continued allowing LatencyMon to run and finally shut it off at 45 minutes. I never once had a spike.
I've checked this like 5 times now over the course of a couple weeks and every driver except Dell's is off the charts with DPC latency. (The Dell NVIDIA beta does poorly, too.)
20th December 2011, 01:32 AM #3
Re: M18x GTX 580M DPC Latency Problems using Dell beta and NVIDIA Reference Drivers
You are absolutely on to something. I have also noticed this problem for some time and have the same results.
Sent from my iPad 2Alienware Nebula Red M18x | 1920x1080 | i7 2960XM | 580M SLI | 512GB SSD, 640GB 7200RPM HDD | 16GB DDR3@1866Mhz | Blu-ray | Intel 6300 | Bluetooth 3.0 | WirelessHD | Tactx KB & Tactx Mouse | G13 & G35 | XBox 360 Wireless Gaming Receiver | Cisco E4200 2.0new iPad 4 64GB 4G LTE AT&T 2048x1536 Retina Display
| Parrot AR Drone 2.0Assassins Creed White PS Vita w/32GB Card
Origin | Steam | Playstation Network | XBox Live | Apple iOS GC: skygunner27
20th December 2011, 01:41 AM #4
Yep I have it too, although I wasn't even aware of it until I read it. =p
Alienware M18x - Space Black | Intel i7 2670QM | Dual 2 GB NVIDIA 580M SLI Enabled | 8 GB DDR3 @ 1600 MHz | 500 GB, 7200 RPM HDD | 18.4-inch WideFHD 1920 x 1080 WLED
20th December 2011, 02:31 AM #5
Please post screen shots of LatencyMon showing the problem (compliant sized images) and a short note indicating which driver you are using.
What prompted me to change my mind and go back to Dell's driver was issues with games crashing/freezing. I'm going to test the Dell drivers further to see if it helps with that. I did not perceive any issue from the DPC latency originally, but I may have concluded that in haste. I think these two things are related because the freezing is usually preceded by a stuck audio loop for 1 or 2 seconds. This does not happen daily, but it happens randomly more than enough for me to want this issue fixed.Alienware M18x R1 v2.0 | Intel Core i7 3920XM @ 4.8GHz | NVIDIA GTX 680M SLI
20th December 2011, 03:36 AM #6
I'll run the check in a few minutes after I get done installing arkham city. Do we need to make sure nothing is running in the background before doing the test? I think I read somewhere that if the CPU is active the dpc latency goes down?
Edit: Ok its just what I thought. When I have the nvidia control panel open with an active 3D nvidia logo, the DPC latency drops WAY down to normal levels. So as long as it drops during 3D gaming, I don't really care what it does in 2D. See attached photo.
Driver used: 290.36 betaLast edited by 5150Joker; 20th December 2011 at 03:55 AM.
AMD 7970M Xfire vs. 680M SLI Review | All Powerful Alienware Steam Group | 680M SLI + BF3 Video
Desktop: Corsair C70 Vengeance | ASUS Maximus V Formula | Intel 3770K@4.5 GHz | EVGA SC Geforce GTX TITAN SLI | 16 GB Corsair Vengeance 2133 MHz | Corsair H100i | Corsair AX1200i PSU | Samsung PM 840 500 GB + 1 TB Seagate 7200 RPM | CM Storm Cherry MX Blue | Logitech Z506 5.1
Display:LG 27EA83-D (LOVE IT!)
Laptop: Sony VAIO SVS15 - 4.4 lbs of awesomeness.
Sold: Alienware M18x-R1
20th December 2011, 03:45 AM #7
Here's my results on 6990Ms with Wi-Fi on (bad latency), and with Wi-Fi off (good latency)
Alienware M18x | Dual 2GB 6990M | Intel i7 Extreme 2960XM with factory overclock to 4GHz | 16GB DDR3 RAM @ 1600MHz
3D Mark 2011 - 7457 | 3D Mark Vantage - 25652
__________________
Alienware M18x | Dual 2GB 580M | Intel i7 Extreme 2960XM with factory overclock to 4GHz | 16GB DDR3 RAM @ 1600MHz
3D Mark 2011 - 7260 | 3D Mark Vantage - 27082
20th December 2011, 07:23 AM #8
Latency Issues here too, with my 580sli system & Nvidia Drivers.
Spoiler :
EDIT:
I too noticed exactly the same as Joker - with the CP open, latency remains at or around sub 200....
Spoiler :Last edited by steviejones133; 20th December 2011 at 07:39 AM.
Main PC
| M18x R1 | Nebula Red | I7 2960xm OEM & 3-Pipe Heatsink | Dell 2gb vRam Nvidia GTX 680m SLI | 1920x1080p WLED | x2 256gb Samsung PM830 SSD's Raid 0 | 16gb HyperX 1866 | Blu Ray Combo | Bluetooth 375 | Bigfoot Killer 1103 | Win 7 Ultimate/Win 8 Pro | NotePal U3 | UltraSharp U3011 30" 2560x1600 RGB IPS Monitor | Logitech G13, G19, G9X | Harman Kardon SoundSticks III | 4yrs Complete Care.
Baby PC
| Toshiba Z830 13.3" Ultrabook | 4gb Ram | I3 2367m | 128gb mSata | Win 7
20th December 2011, 07:45 AM #9
Can someone run it in th ebackground on a 2nd monitor with a game running on the primary?
__________________
20th December 2011, 08:16 AM #10
Just done that - other way around though. Game on my external and monitored on the laptop internal. Played Crysis 2 for a litte bit and latency seemed to hover within limits around 200us. After gaming for 5-10mins, and monitoring from the outset, the message was that my system was good to handle real time audio etc.
I repeated the process so the game was on the internal whilst I had the monitor on the external with extended display. Same result, all seemd ok to me.Last edited by steviejones133; 20th December 2011 at 09:51 AM.
Main PC
Baby PC
LinkBack URL
I`m upgrading, are you? (GTX 780M...
Today, 07:08 AM in Gaming (Software and Graphics Cards)
