Quantcast R3 wont post, need help asap
Results 1 to 6 of 6
  1. #1
    Jul 2011
    Suffolk, UK
    Default R3 wont post, need help asap
    So I was trying to get the damn switchable graphics to work, but it kept giving me 2 monitors instead of just 1. And the FN+F7 wouldn't do anything. I have the modded a10 bios and was messing around with some of the settings. I can't remember what I did, but I think it had something to do with changing the settings for the display. Now when I try to power on, it just gives me a black screen, no fans power on, and I can hear a slight ticking sound (not the same as a HDD tick). Any idea on how to get past this? I have looked around for how to blind flash the bios, but nothing has worked. I even tried resetting the bios by removing the battery, but no luck so far.
    M17x R3 Stealth Black | i7-2920XM | AMD Radeon™ HD 7970M
    16GB 1600Mhz Corsair "VENGEANCE"| 1920 x 1080 60Hz WLED
    120GB OCZ Vertex III + 750GB 7,200RPM HDD
    Blu-ray Reader | Killer™ Wireless-N 1103 | Razer Mamba 2012
    Guide: How to fix screen dim issue on R3 w/ 7970M
  2. #2
    T|I
    Nov 2010
    Default Re: R3 wont post, need help asap
    Remove the AC adapter, battery and coin cell battery for a couple of mins, this will reset the changes you made in the BIOS and it should be back to normal.
  3. #3
    Jul 2011
    Suffolk, UK
    I already tried that, but no luck. I'll give it another shot. I gotta go get my haircut, so I'll leave it out while I go and do that.
  4. #4
    Alien Samurai
    Nov 2010
    San Diego, CA
    Ouch. If the battery resets don't work, you can always try plugging in an external monitor to the VGA port and see if it posts to that. Otherwise, you might need a new motherboard, bruddah!
    "You can call me Night Hawk."
    Alienware M17x-R2 Lunar Silver:
    Intel i7-920XM | 1920x1200 LCD |
    AMD Radeon HD 5870M |
    8GB Vengeance PC3-12800 DDR3 RAM |Sound Blaster Recon3D Omega Wireless |
    Intel Centrino Ultimate-N 6300 |
    BD-ROM/DVD+RW/DL |
    240GB Kingston HyperX SSD
    + 2 x 750GB Western Digital Scorpio Black HDD |
    Windows 7 Ultimate x64 | Notepal Cooler Master U3 |
  5. #5
    Jul 2011
    Suffolk, UK
    Battery reset didn't do anything. Just sits at a black screen with a tapping sound
    Edit: Alright guys, I resolved my issue. I removed my 7970M and when I restarted it gave me the 5 beeps. I checked with Dell and it states that 5 beeps is a bad CMOS battery. I reseated the battery and it booted up. I checked the bios and made sure to change my drive boot order and change from raid to AHCI. It booted up just fine. Reinstalled my GPU and it booted without an issue. Thank God it's not the motherboard.
  6. #6
    Company Representative
    May 2012
    Quote Originally Posted by SkylineLvr View Post
    That was pretty quick! Great TS btw +1
    Here's the Beep Code table for further reference.
    Luis Pardo
    Dell | Alienware Technical Support Alienware Arena
    Opening your case and/or replacing parts yourself does not void your warranty, check our disassemble videos on YouTube
    Quickest way to get support from Dell: Twitter via @AlienwareTech or Facebook.com/Alienware using the "message" link.
    I can't always reply to PM's, please for extra assistance use any of the Facebook and Twitter links
