Quantcast need help, fans stop working
Results 1 to 8 of 8
  1. #1
    Mar 2011
    Default need help, fans stop working
    Hi, recently I get a lot of blue screen which i don't know what have caused it. Until now I figured out that the fan on the right side stop spinning when the laptop is on. So i guess the high temperature cause the system to shut down or reboot.
    I have attempted several things:
    1. updated BIOS from A3 to A10 (didn't help)
    2. reinstalled Window 7 (didn't help)
    3. swap the right side fan with left side, it works, so I assume the 4pin connector on the motherboard might have problem.
    4. swap the left side fan to the right side, still not working.
    I want to fix this problem before calling Dell for assistance because it might take them forever to come down here I assume.
    Any suggestion or help would be very appreciated!
  2. #2
    Dec 2011
    Kazakhstan, Almaty
    Default Re: need help, fans stop working
    Quote Originally Posted by whereisit View Post
    What's your spec?
    For how long are you using your laptop?
    Current rig: M18x R2, 3820QM, 16GB DDR3 Kingston HyperX 1866mhz, DELL GTX 680M SLI, RAID0 Samsung 830 256gb ssd's, intel 6300 FTW (ordered from hidevolution.com)
    3DMark11 - P11452 (950/1470mhz): www.3dmark.com/3dm11/4395511
    Went to wife:
    Alienware m17x R3 2860qm, 16gb ddr3 1866mhz, 6990m (looking for DELL 7970m), intel 520 series 240gb SSD, bigfoot killer 1103
  3. #3
    Mar 2011
    Quote Originally Posted by Heihachi88 View Post
    What's your spec?
    M17x R3
    CPU: i7-2630QM
    GPU: AMD 6790M
    HDD: 320GB @7200 RPM
    RAM: 4GB 1333Mhz
    Wireless card: DW1501, 4313
    I have had my laptop for 1 year now, and I get blue screen between 15-20min of usage.
  4. #4
    Jun 2011
    Canada
    If you tried switching the fans and both fans work on one side and not the other it indeed looks like a problem with the connector. If that's the case you're going to need a new motherboard and you're going to have to contact Dell to send a tech over to replace the motherboard for you.
    Although they may be due to either your faulty motherboard and/or overheating, I can help you with your bluescreens if you zip and upload your dump files from C:\Windows\Minidump\
    Alienware M17x R3 Stealth Black | i7-2920XM OEM | 460M | Corsair Vengeance 16GB DDR3 1600 | 256GB Corsair Performance Pro | 320GB HDD | 1920x1080 60HZ | Intel 6300 | G700 | Blackwidow Ultimate | SF-19 USB 3.0 (Modified)
    MSi GT683-DXR | i7-2670QM | 570M | Corsair 16GB DDR3 1333 | 500GB HDD x2 RAID 0
    Alienware M17x-R3 Service Manual
    Alienware M17x R3 User Manual (PDF Download)
    Alienware M17x R3 Service Manual (PDF Download)
    Alienware M17x R3 CPU & GPU Re-Pasting Guide w/Pics!
  5. #5
    Dec 2011
    Kazakhstan, Almaty
    Quote Originally Posted by aznpos531 View Post
    Indeed, sounds like a failed fan connector on motherboard. Are you elevating back of your laptop or using cooling pad? Maybe it failed because of heat issues.
    Went to wife:
  6. #6
    Mar 2011
    Default
    If i want to use my laptop i need to turn on a regular fan on high speed and point directly to my laptop, so it won't overheat. I think I will contact dell. thanks for replies.
    I recently reinstalled window, so I don't think there is anything left over? In fact, I haven't even install all the drivers yet because I am using my other laptop, MSI GT 683R
  7. #7
    Jun 2011
    Canada
    haha yea, if that's the case the dump files are gone.
    I just recently got a GT683DXR. Excellent system for the price!
  8. #8
    Mar 2011
    I just want to express my feeling toward Dell tech support. I told them that I reinstalled Window by myself, and also have swapped the fans to test it, and the agent told me that I DISQUALIFIED for the warranty. Is this a joke? I was be honest with them. I swear I would never buy any Dell product again. This is very ignorant when they say stuff like this. I was explaining that I was testing the fan so it makes it easy for them to troubleshooting the issue for me, instead he said "unfortunately, you are disqualified for warranty for modifying the hardware". My experience is that Dell does not want to waste time and money fixing problems due to laptop hardware failure. Dell sting so much!
    At the end of the day, the agent offers me to send my laptop to the repair center with free of cost including shipping and handling after I said that I have not modify any hardware or do any damage.
