Results 1 to 3 of 3
Thread: Light problems after formatting
4th June 2012, 06:47 PM #1Newbie
- Join Date
- Jun 2012
- Posts
- 1
- Rep Power
- 0
Hi all,
Is the first time I write here.
A few months ago I had a problem with lights. After formatting I install the drivers and gave me an error when installing the FXlight drivers and it did not have returned to work since then, I tried to reformat but did not work.
Has anyone had the same problem?
And a posible solution?
thanks
5th June 2012, 01:25 AM #2Notebook Deity
- Join Date
- May 2011
- Posts
- 775
- Rep Power
- 9
Re: Light problems after formatting
Did you by any chance happen to install the command center from the resource disc? If you ended up doing that (and it was an older cc version) the lights won't work anymore. As far as I know, only a new mobo will fix that now.
M15x | 1920x1080 | i5-540m | Crucial 8gb 1066mhz | DVD-RW | AMD 5850m (11.7)
| seagate momentus 240gb | Windows 7 - 64 bit | Bigfoot Killer 1102 | Logitech G7 |
5th June 2012, 01:52 PM #3
Here's some troubleshooting that you can follow to fix the issue. If after performing this troubleshooting the issue continues to be the same please send us an e-mail to AWSocialMedia@dell.com including your service tag and phone number and we will get back to you as soon as possible, after the resolution let us know here on the forum what happened so that the community know the outcome.
Luis Porras
Dell | Alienware Technical Support
Opening your case and/or replacing parts yourself does not void your warranty, check our disassemble videos on YouTube
Quickest way to get support from Dell: Twitter via @AlienwareTech or Facebook.com/Alienware using the "message" link.
I can't always reply to PM's, please for extra assistance use any of the Facebook and Twitter links
LinkBack URL
2013 Alienware Notebooks revealed
11th June 2013, 12:46 PM in Alienware
