Results 1,031 to 1,040 of 1171
24th August 2011, 02:25 AM #1031
Re: M15x Problem/Technical Question thread
Hi all. When I use my laptop on battery only, I've noticed that CPU clock is very low (around 300-400 Mhz) so every application was running very slow. Is there any one know how to increase CPU clock?
P/s: I was using High performance power settings with both Battery mode & plugged in have the same valueAlienware M15x Cosmic Black | Core i7-740QM | 1.5GB DDR5 GeForce GTX 460M | 8GB DDR3 | 120GB OCZ Vertex 2 SSD + 500GB Momentus HDD | 1920x1080
Razer Orochi | Razer Kabuto | Alienware Tactx Headset | FiiO E7 | Sennheiser IE7
24th August 2011, 03:57 AM #1032Newbie
- Join Date
- Jan 2011
- Posts
- 5
- Rep Power
- 6
Alienware m15x permanent Alien FX problem, solved
i have problem with my alienware area51 m15x,.
Alien fx gone. all lights become dark, and not responding for any solution method.
I have spent with this almost 3 days, with no success.
reflashing wetre not possible coz command center (no dif of it ver.) said, THERE IS NO ALIEN FX controller found. All lights are dark, even pow. button.
after MANY MANY tryies of many many methods it still dark.
the conclusion was::::: "ALIEN FX DIED" : ( :( (bios res, and other more advanced steps were not solve the problem, ever system reinstallation and ALL of drivers were tested with no result)
there is hardware solution to permanent alien FX lights ON.
you can chose your favorite colour by combination of 000,001,010,100 ..., 111 = all are flashing R+B+G = WHITE
(3 photos included)
24th August 2011, 08:43 AM #1033
Hello.
I have an Area 51 m15x. I got it really cheap off someone else because it was 'broken'. The issue is that when you press the power button, the laptop turns on (lights turn on, can hear that it's switched on) but the screen remains black. The previous owner said that it was a broken screen, but I'm dubious. The screen itself looks fine (no cracks etc), but I always thought that this problem was normally to do with the graphics card?
Any advice? It has the 8800M GTX if that helps.
EDIT: would hooking it up to an external monitor work? (i.e. if it works, it's the screen that's dead. if not, it's the graphics card? or could it be a completely different problem altogether?)Last edited by nina-9; 24th August 2011 at 09:06 AM.
24th August 2011, 08:52 AM #1034
Re: Alienware m15x permanent Alien FX problem, solved
M14x R2: Stealth Black | 14" HD+ 900p Display | 3rd gen Intel Core i7 3720QM | 8gb DDR3 RAM | 2gb GDDR5 GT650M | Killer Wireless-N 1202 | 64gb Samsung PM830 mSATA SSD Boot Drive + 256gb Samsung 830 SATA III SSD + 1tb 5400RPM portable external USB 3.0 HDD
M11x R2: Stealth Black | i5 | 4gb RAM | 450gb HDD - (Sold)
24th August 2011, 09:38 AM #1035Newbie
- Join Date
- Jan 2011
- Posts
- 5
- Rep Power
- 6
24th August 2011, 09:48 AM #1036Newbie
- Join Date
- Jan 2011
- Posts
- 5
- Rep Power
- 6
IT IS VERY EASY TO CHECK WHAT EXACLY IS CRASHED.
Remove your dedicated GTX, and just turn on your Alienware without it. there is second Intel Graphic kard onboard, which become primary.
you can even normally work on it.
Probably you need to repair your VGA, (BGA Reballing (because of high temperature, but its normal in all machines to reball afret 3 years approx ), it can be made by any laptop service.that why your LCD is darknes.
if you can off your laptop after it starts (5sec hold of p.button) then probably your laptop is fine.
just remove DEDICATED VGA, and check again. (PS. if your lcd is broken, it also can be invisible, check its that become gray , when u start your Alien
24th August 2011, 09:56 AM #1037Newbie
- Join Date
- Jan 2011
- Posts
- 5
- Rep Power
- 6
also check, if you able to turn it off immidiatly. if it shut down imidiatly you touch the button, then its 100% OK. if not, then do not panic yet, coz computer can be halt it self at bios bootup, coz bios occured some VGA error, and stacks.
24th August 2011, 10:02 AM #1038Newbie
- Join Date
- Jan 2011
- Posts
- 5
- Rep Power
- 6
dont worry, it is very easy to remove this VGA. it takes about 2 minutes. open your bottom cover and find vga cooler, its on left up corner (its up side down), it have 2 screws, easy to remove. next 4 screws with numbers on GPU module. Thats all. it looks similar to your DDR inside, but biger one. it have very similar slot
28th August 2011, 12:05 PM #1039Notebook Consultant
- Join Date
- Jul 2011
- Location
- Boise, ID
- Posts
- 186
- Rep Power
- 5
I'm gonna toss up another webcam issue here, I yanked the keyboard from my M15 not too long ago, the webcam was in fact plugged in. When I do fn f9 the OSD pops up enabling or disabling the webcam however it doesn't show in device mangler. Windows doesn't detect any undetected hardware either. I tried the M17 webcam driver for fun with no success. At this point I'm not sure what exactly to do as I've done the power drain a couple times. Is there a plug on the webcam side of the cable or is it permattached to the hardware? For that matter the on board mic doesn't work either.
M15x Nebula Red, i7 740, Radeon 5850, 320 gig hdd, 4 gigs RAM, bluray drive, 1600x900 screen.
7th September 2011, 08:16 AM #1040Notebook Enthusiast
- Join Date
- Dec 2010
- Posts
- 33
- Rep Power
- 6
Hi all.. Recently I updated nVidia drivers for my GTX 460M to 288.26.. While gaming or movie watch sometimes evn when it is idle I get a noise from machine which hangs laptop for 10 to 20 seconds and some times lead to the blue screen even when it is idle.. the temperatures are also constant.. not exceeding more than 73 C while gaming and 55 C while watching movie.. At idle times it remains from 45 to 50 C.. I've even changed drivers to 275.33 and very own Dell provided 259.xx too.. But the problem still remains.. Got any solution for this? Thank you in advance.. :-)
M15X/i7 740Q/460M 1.5GB/4GB/1080p/BR ROM
2Likes
LinkBack URL
I`m upgrading, are you? (GTX 780M...
Today, 10:11 PM in Gaming (Software and Graphics Cards)
