Results 1 to 8 of 8
16th August 2012, 08:11 PM #1
Wireless cutting out and going slow after extended use (Killer Wireless-N1202)
Hi guys been having this problem form a while now and I'm fairly sure it's the card and not the modem nor the game
When gaming, after a couple of houris of playing my wireless begins to cut out for about 3 seconds before reconnecting then sometimes proceeds to go quite slowly for another 20 seconds before picking back up to normal speed - then repeating this 30 seconds later. This is obviously extremely frustrating. If I'm quick and have the killer wireless program open i see it flash to device not detected then back to normal
Iv installed the most recent drivers for the card Killer Wireless-N 1202. When I ran alien autopsy it failed the "Network Link Test". I haven't got mcafee installed
Anyone have any ideas? ThanksM14x R2: Stealth Black | 14" HD+ 900p Display | 3rd gen Intel Core i7 3720QM | 8gb DDR3 RAM | 2gb GDDR5 GT650M | Killer Wireless-N 1202 | 64gb Samsung PM830 mSATA SSD Boot Drive + 256gb Samsung 830 SATA III SSD + 1tb 5400RPM portable external USB 3.0 HDD
M11x R2: Stealth Black | i5 | 4gb RAM | 450gb HDD - (Sold)
16th August 2012, 09:36 PM #2
Re: Wireless cutting out and going slow after extended use (Killer Wireless-N1202)
Ive had this problem as well. What I did was i stopped the killer network management program from running at start up and never use it again. Seems to have fixed the problem and have not had any disconnects anymore, ever since.
M14xR2 | i7 3610QM | 1GB Nvidia GT 650M | Corsair Vengence 16GB 1600 Mhz RAM | | Killer wireless 1202 | 900p Screen| Corsair Neutron GTX 240GB SSD
16th August 2012, 10:12 PM #3
My G73Jh uses a low end Atheros chip, and suffers from a constant disconnection issue when it is in only two rooms away. I found that I was able to resolve this by changing its Adaptor properties, and setting the Scan Valid Interval setting higher.
My M14x also has Killer 1202 wireless, but mostly did not appear to have this problem, but it did disconnect twice. I decided to increase the Scan Valid Interval setting for it as well, which appears to have eliminated disconnections entirely.
If I'm not wrong, this basically increases the maximum ping-timeout interval. The higher the value, the longer the wireless controller waits before registering a disconnection or ping-out.
Do note though, that I think this might increase latency.Last edited by salanos; 16th August 2012 at 10:24 PM.
Gallatin - Core i7-3930K - 32GB DDR3-1600 Ripjaws Z - GTX 560Ti 1GB GDDR5 Twinlight Turbo - Rampage IV Extreme - Kingston HyperX 128GB + 3xHDD - 22x DVDRW + 22xDVDROM - Corsair AX1200 - Thermaltake Level 10 GT Snow
Crimson Spectre (EDD: 14/8/2012): Nebula Red M14x (SPECTRE-MLK V510402SG) - i7-3720QM - 16GB DDR3-1600 - GT 650M 2GB GDDR5 - 7.2K 750GB+32GB S.R.T. - 4x Blu-ray - HD+ - Killer 1202
17th August 2012, 03:22 AM #4
18th August 2012, 09:10 PM #5
Tried both of these but neither worked
Now the problem seems to be frequent (every minute or so), intense lag spikes (im talking from 40 --> 4000ms) lasting a few seconds. iv tried multiple connections, multiple games, multiple drivers and fiddled with the settings to no end but i still get this problem. Thinking its time to contact Alienware and see about getting a replacement card... Any other thoughts/recommendations before i contact them?
19th August 2012, 01:16 AM #6
Ok so after all day getting extremely frustrated i thinkk i MAY have fixed it *touches wood*. This is what i did
1. Installed DriverMax
2. Completely uninstalled the Killer drivers/software, restarted, then used the Bigfoot cleaner and ran CCleaner then restarted again
3. Used drivermax to find and install the most recent standalone driver (without the Killer software) then restarted
4. Downloaded (from this site - download the top (larger) install rather than the stand alone driver as that alone did not work for me) and installed bluetooth driver separately
So far so good - no massive 2000ms spikes though i have yet to do an extended test. Hopefully this might help out anyone else with similar issues
EDIT: Seems to be working well after 2-3hrs of play time (still getting the odd spike but nothing like before)Last edited by laz91; 20th August 2012 at 12:57 AM.
20th August 2012, 12:34 AM #7Notebook Enthusiast
- Join Date
- Aug 2012
- Posts
- 34
- Rep Power
- 2
Good job, gotta love driver bugs lol
20th August 2012, 12:54 AM #8
I also had to install the Bluetooth driver separately (edited previous post with link). Gave it a decent test last night and although i get infrequent spikes after playing for 2+ hours its much better than before
Haha thanks and to think it only took like 3 hours... lolM14x R2: Stealth Black | 14" HD+ 900p Display | 3rd gen Intel Core i7 3720QM | 8gb DDR3 RAM | 2gb GDDR5 GT650M | Killer Wireless-N 1202 | 64gb Samsung PM830 mSATA SSD Boot Drive + 256gb Samsung 830 SATA III SSD + 1tb 5400RPM portable external USB 3.0 HDD
LinkBack URL
I`m upgrading, are you? (GTX 780M...
Today, 04:53 PM in Gaming (Software and Graphics Cards)
