Quantcast Help Skyrim FPS problems
Results 1 to 7 of 7
  1. #1
    Sep 2011
    Default Help Skyrim FPS problems
    I'm playing Skyrim on medium and only getting 11-14 fps
    My specs are
    i7 2670QM 2.2 GHz
    6GB RAM
    1.5GB GPU
    The problem with this ing game being on steam means that I cna't select it and tell it to run with GPU, idk if that's the problem but I don't think I should be getting such a low FPS. I've only done the opening cart scene I haven't moved past that because it's performing so badly
  2. #2
    Apr 2011
    Chicago
    Default Re: Help Skyrim FPS problems
    Skyrim auto sets to the Intel GPU, and you can whitelist steam games. Just go to Program Files (x86)\Steam\steamapps\common\skyrim and whitelist the exe file. Skyrim is also optimized for PC very badly. You can check the 'Skyrim Early Download Thread' for my settings on how to get it running better.
    Alienware M14x: i7 2630QM 2.0ghz; NVIDIA GT555M 3.0GB @ 800/1050/1600; 8GB DDR3 RAM 1600mhz; 64gb Crucial M4 SSD + 500GB 7,200RPM HDD; 14.0 in. WLED HD+ 1600x900 Display; Intel 6205 Advanced WiFi; Klipsch 2.1 Stereo Speakers w/ Subwoofer
    Check out my YouTube for M14x gaming videos. | Add me on Steam. | Go here for M14x signature bars. |
  3. #3
    Sep 2011
    I'm running it on high at a steady 28-32 FPS.
    This little orc is quite happy!
    I bought the box, not the download, because I wanted that nice map...
    http://the-skyrim-blog.blogspot.com/
    M14x i7 2630, 1.5 Gb GT555m, 6Gb RAM, 900pee, 500 Gb Bluetooth, Black
  4. #4
    Oct 2011
    So i've been playing for 1 hour and had over 35 fps , usualy 40-50 the whole way thru on high settings (the default one). And I only have the i5 2410m ? go figure, but I love it
    Im OC at 700/1400/950
  5. #5
    Jun 2011
    the world i get 40fps. never dips. but when i go indoors it dips and sometimes stutters. no overclock or turbo boost though. i need to play around with it. i want to hook it up to my tv
  6. #6
    Sep 2011
    I'm running 1080p OC'd at 750/1500/1050, textures high, decal ultra, shadows medium, AA 4x and AF 12x. I average 30-50fps outside and in most indoor areas. But certain indoor areas (cave settings seem to hit the hardest for some reason) with lots of fire can make it drop to around 26. The lowest I've noticed it dip was 23 but that was only in one particular spot so far.
  7. #7
    NBR Community Moderator
    Feb 2006
    The Bay
    Lets start using this thread for Skyrim -
    M14x Skyrim Performance/Questions/Best Driver/Settings & General Chatter - Discuss Here....
    Thanks everyone!
