Results 651 to 660 of 688
31st August 2011, 12:35 AM #651Newbie
- Join Date
- Aug 2011
- Posts
- 9
- Rep Power
- 5
Re: M11xR2/R3 - NVidia Optimus Issues/Whitelisting Problems
Omg thank you so much. I really appreciate it...I would never figured it out xD
1st September 2011, 01:13 AM #652Notebook Consultant
- Join Date
- Aug 2011
- Posts
- 107
- Rep Power
- 5
5th September 2011, 05:24 PM #653
I am having trouble running dvdfab8 with cuda , I had to manually whitelist dvdfab , but as soon as i start ripping the optimus icon on the taskbar lights-up and dvdfab crashes, I have tried a number of times and i cannot get it to work, I am using 280.26
Thanks.ALWAYS MAKE A SYSTEM RESTORE POINT BEFORE INSTALLING OR REMOVING ANY SOFTWAREDONT FLASH NEW FIRMWARE WHEN IT FIRST COMES OUT, WAIT TO SEE IF THERE`S ANY PROBLEMS FIRST
Lenovo Ideapad Z580 i5-3210m HD4000 Win7 x64 8gb 1600MHz Samsung 830 256GB SSD Win7 x64
14th September 2011, 08:06 AM #654Notebook Enthusiast
- Join Date
- Sep 2011
- Posts
- 13
- Rep Power
- 5
Has anyone had this issue with latest source engine games?
I have a R3, and Counter Strike source for example, does correctly use the 540m.. BUT it doesn't seem to detect it properly in terms of my settings. The highest shadow quality I can choose is medium. So the performance is the correct card, but the game thinks its using the integrated..
19th September 2011, 10:38 PM #655
Pretty sure Portal 2 counts as a recent Source-powered game. On my R2, it seems to properly detect the 335m, allowing usual max settings. Didn't have to whitelist it.
21st September 2011, 02:58 AM #656Newbie
- Join Date
- May 2008
- Posts
- 1
- Rep Power
- 0
I've just noticed that Optimus seems to have stopped working entirely. I hadn't used this laptop (M11xR2) for gaming for a couple of months, then went to run FM2011 (of all games), and noticed that when using the 3D match engine, the frame rate drops considerably. I checked Optimus and noticed that the GPU activity is none. The game is whitelisted, and the NVIDIA processor is the default card for the executable.
It's the same for all of my games. Crysis 2, Portal 2, Shogun 2, CIV5, Amnesia, and so on.
I haven't downloaded or installed anything significant since the last time I know it was working (around a week after Portal 2 was released I'd guess).
Any recommendations? I'd try a clean driver install, but I'm stuck on mobile internet at the moment. Is there anything else that I could do?
Cheers
Edit: I guess I should the driver version: 270.61.
24th September 2011, 03:26 PM #657
doesn't work with my AIDA64 as well, it wouldn't turn on for it so i can't check the full specs of it. It is on the list, and selecting to launch with nvidia graphics don't work either...
wish i could just force it to stay ON when i want it... While optimus is a smart option for every day consumer, it is a huge nuisance to enthusiast or expert.[M11x R3]
[I5-2537M (2037Mhz)]
[16gb Ram(1333Mhz)]
[120gb patriot inferno SSD]
[540GT(782core 1050ram)]
Looking for someone willing to help to locate fuses on my asus 1215n motherboard as i fried some, can't find them though... PM if got any helpful information please ^_^
24th September 2011, 03:47 PM #658
I never have any problem with Optimus. Maybe all of the games I'm playing (Bad Company 2, Starcraft II, Dirt2, Left 4 Dead 2, Counter-Strike, NFS Shift & NFS Hot Pursuit) works well with Optimus. Make sure you have latest driver from Nvidia installed (not Dell). You can use GPU-Z to see Nvidia GPU specification. If want to check it with AIDA64 or HWiNFO32, the trick is to run GPU-Z or open a video in the background. (In GPU-Z window, select the Nvidia GPU. If playing video in the background, make sure the player is in Nvidia control panel whitelist to use the Nvidia GPU.) The reason why AIDA64 doesn't see the Nvidia GPU because it is inactive.
Dell Studio 1557 | Intel Core i7-720QM - CPU Microcode Update Rev 4 | 4GB | dGPU: ATI Mobility Radeon HD 4570 + eGPU: PowerColor HD 5870
Asus A42JV/K42JV | Intel Core i5-450M | 4GB DDR3 1066MHz | nVidia GeForce GT 335M 1GB DDR3 with Optimus technology | WLED 1366x768 14"
Phoenix BIOS MOD Request | Acer Notebook Clock Generators/PLL | Guide to BIOS mod for Dual-IDA
24th September 2011, 04:51 PM #659
And i hate the bit that I CAN'T MAKE IT ACTIVE. I hate not having absolute power over my laptop! Respect my authortha!
anyways it would really be nice to be able to manually switch nvidia card on/off when you want to not wen it feels like it... it doesn't work with older games as well... haven't tried em recently, maybe new drivers fixed it.[M11x R3]
[16gb Ram(1333Mhz)]
26th September 2011, 02:53 AM #660Overclocker
- Join Date
- Jan 2010
- Posts
- 896
- Rep Power
- 12
Has anyone tried using FXAA on an Optimus system? I tried it and I can't force it to use anything other then the Intel GPU. Guess I'll have to wait until it is implemented into the drivers officially.
LinkBack URL
2013 Alienware Notebooks revealed
11th June 2013, 12:46 PM in Alienware
