Quantcast M17 R1 - Power Problems: How do I access the motherboard?
Results 1 to 10 of 10
  1. #1
    Jun 2011
    Default M17 R1 - Power Problems: How do I access the motherboard?
    Ok, forgive me if this has been answered before. I'm currently having power problems on my M17 R1 - I plug it in from the AC adapter (battery in or out doesn't matter) but the laptop doesn't seem to "see" that it is plugged in. I've gotten it to work once in the last couple weeks. I'm thinking there might be something wrong with the DC plug on the motherboard itself and I'd like to take a look but I'm not entirely sure what to remove on my case to get access to the motherboard parts like the DC power plug. Is there some sort of guide someone can point me to so I can see how to take a closer look at it? Thanks!
  2. #2
    ATI+AMD -> DAAMIT
    Aug 2009
    Default Re: M17 R1 - Power Problems: How do I access the motherboard?
    you pretty much need to disasemble the whole thing
    Alienware M17-R1 Disassembly-Assembly Guides Nu!Netherlands News Weblog
    Core™ 2 Extreme Quad QX9300 3.7GHz (Still stuter free ^^)
    CrossFireX™ 1GB ATI® Mobility Radeon™ HD 4850
    17-inch 1920 x 1200 LCD
    8GB hyperX Dual Channel DDR3 at 1067MHz
    7 Ultimate x64 sp1 Kingston ssdnow 96gb + hitachi 500 GB
  3. #3
    Jun 2011
    Thanks! That looks involved but doable.
    Is my thinking right on this? If I plug in an AC Adapter that I am pretty sure is working and the "plug" LED indicator doesn't light up on my status panel then I should start looking at the DC plug on the Mobo?
  4. #4
    ATI+AMD -> DAAMIT
    Aug 2009
    depends on what adapter you are talking about any adapter that you wanna use with the m17 must be at least 120w for them to stay on
    you can test with the 90w or 60w but they will shut down after just a few seconds ps dell's adapter works with this laptop to
  5. #5
    Jun 2011
    I have a 220W adapter (20V @ 11A) so that should work. However, I'll see if I can borrow someone's adapter with a "barrel" connector and see if that works. Even if its the incorrect Wattage should the "plug" indicator on the status bar turn on?
  6. #6
    ATI+AMD -> DAAMIT
    Aug 2009
    only dell branded ones will light it the no brand don't
  7. #7
    Jun 2011
    Even on a pre-Dell model Alienware (M17 R1)?
  8. #8
    ATI+AMD -> DAAMIT
    Aug 2009
    at least the generic i tryed didn't
    so far i know that the flexes do work and the dell do also
    others didn't
  9. #9
    Jun 2011
    Can anyone tell me (before I disassemble the whole thing) if that DC power jack is micro-soldered or regular soldered to the mobo? If it's a micro-solder I don't think I'll even try to replace it.
  10. #10
    Aug 2011
    I had the same problem ended up being the graphics card went bad
