Quantcast Help! My M18x won't connect to my TV?
Results 1 to 4 of 4
  1. #1
    Jun 2011
    Default Help! My M18x won't connect to my TV?
    I ran an HDMI wire from my M18x to my TV. It appears the Samsung Plasma picks up the connection as "HDMI2" device pops up, which is the port it's connected to and does my PS3 with.
    How come then video isn't immediately transmitted? What's going on? Please help me I really wanted to stream video on the TV and see how it looks.
    Alienware m18x - Space Black, i7 2630QM | 8GB DDR3 RAM, Dual 1.5GB NVIDIA GeForce GTX 460M SLI, 2x500GB SSHD
  2. #2
    Nov 2010
    UK
    Default Re: Help! My M18x won't connect to my TV?
    Right click on desktop - 'Nvidia Control Panel'
    Select - 'Display' - 'Set up Multiple Displays'
    Set up the options you want, not forgetting to click 'apply'.
  3. #3
    Jun 2011
    Thanks, it just worked! I made it so when I close my lid, the PC does nothing. I did notice it lost signal once before I tightened it a little in back of my PC and reinserted, I wonder if that's a cause for concern. It obviously fits flush in the laptop but in back of the TV it looks odd, I'm buying a new TV anyway.
    Are there any programs to improve signal or could that have been a fluke?
  4. #4
    Nov 2010
    UK
    Actually you mentioning about that, I struggled to get HDMI working initially on mine.
    In the end I unplugged and plugged back in and it then worked, wasn't sure it was the actual cable or the socket itself.
    I didn't spend a lot of money on the cable so presumed it was that. Hopefully it's not a flaky socket.
    It works for now so am happy.
SEO by vBSEO 3.6.1
