Quantcast battery charge state light
Results 1 to 10 of 10
  1. #1
    May 2010
    UK
    Default battery charge state light
    Got my new M14x, lovely, works well and put together well.
    I have noticed the battery charge indicator on the bottom does not work, i'm not concerned as i can see how much charge is present when i have it turned on but i'm curious.....Has it not been activated or is there a software fix?
    Cheers
  2. #2
    Jun 2011
    Skyrim, Alienworld
    Default Re: battery charge state light
    You might want t press it harder, for mine I have to press it very hard, sometime I felt like I might break it, lol.
    M14xR1 : 2720QM : 8GB 1866Mhz : GT555M 3GB OC@800/1600/1080 v314.22 : 750GB : HD+ (900p) : Ultimate N 6205 : Win7 Pro 64x :
    BF3 ID: N0vvh3r315s4f3, Steam ID: CGSDR. Feel free to add me, however please also let me know who you are as well to avoid confusion.
    Alienware M14xR1 Resources/Drivers/Goodies | Guide: How to Whitelist games on an Optimus Machine | Alienware M14xR1/R2 Ingrater's AlienFX Plugin
  3. #3
    Apr 2011
    What do you have to press exactly? I can't find any button... O_O
  4. #4
    Jul 2011
    turn the laptop over and directly above the fan there is a little slit with a picture of a battery and 5 squares which should light up when you press the the little slit, indicating how much battery remains
    Alienware M14X - Core i7 2630QM
  5. #5
    May 2010
    UK
    Quote Originally Posted by CGSDR View Post
    Crikey! Your right, you have to press really hard! It works!
    Cheers
  6. #6
    Jun 2011
    Skyrim, Alienworld
    Quote Originally Posted by toondw View Post
    Cheers
    You're welcome!
  7. #7
    Jun 2011
    Los Angeles, California
    Yeah the light is actually on the battery itself. If you unscrew the bottom, you'll see the button and lights on the battery, pretty neat design.
    -Alienware M14x core i7 2630qm, 1.5 gb gt555m, 6gb Ram, 900p Resolution, Bluetooth, Corsair Force GT 180gb SSD,
    -Macbook Air 13 inch, core i5, 128 gb ssd, 4gb ram
  8. #8
    Apr 2011
    Quote Originally Posted by soulhacker View Post
    Found it, thanks!!!
  9. #9
    Jul 2011
    Thanks! This helped me too!
  10. #10
    Mar 2011
    i just put a small piece of duct tape on the inside of the backplate, over the button, so now i dont have to press as hard. works well.
    M14x R2 Black | Intel® Core™ i7 3610QM 2.3GHz | 12GB 1600Mhz Memory
    120 GB HyperX SSD + 750GB HDD | 1600x900 HD+ | 2 GB GDDR5 NVIDIA® GeForce® GT 650M
    Killer Wireless-N 1202 | Windows 8 Pro | Orion Messenger Bag | 1 Year Advanced Warranty
SEO by vBSEO 3.6.1
