Quantcast Skyrim Volume too low? maybe a fix here (worked for me)
Page 1 of 2 12 LastLast
Results 1 to 10 of 16
  1. #1
    Mar 2011
    Mexico
    Default Skyrim Volume too low? maybe a fix here (worked for me)
    Well I'll make this a thread so I think more people will look at it
    When I installed skyrim on my r1 everything was fine, I just noticed that the game volume was too low
    I left the game with the main screen to hear the song and I culdnt hear it without headphones or from 3 meters from the m11x so I found this fix on the internet and some of mine
    on the control panel > hardware and sound > sound menu
    select your speakers (realtek high definition audio for me) then > properties > then go to enhancements tab > and check the loudness equalization, then re-launch skyrim, and check for differences on audio, this helped me but
    then I went to the SRS tab on the sound menu checked to enable SRS technology (this is from realtek HD audio controller) and selected the game option
    then the game really sounded really good and noticed I can hear everythig just fine and not with max volume
    I hope this helps also I have on the advanced tab the sound set to Studio quality 24 bit, 44000 Hz
    greetings from skyrim brothers!
    Alienware M11x
    SU7300 @1.6Ghz Gt 335 @stock clocks 2Gb DDR3 250 Gb HDD @7200 RPM
  2. #2
    Nov 2011
    Default Re: Skyrim Volume too low? maybe a fix here (worked for me)
    I just registered to say Skyrim really has a low volume (maybe only happens in some computers).
    I tried the loudness equalization fix as you said and it really worked for me, and now the volume is higher.
    Saludos carnal :P
  3. #3
    Oct 2006
    Mars
    Quote Originally Posted by el_pitaya View Post
    I tried both these suggestions and the sound seems to be better now. I will test more
    Thanks!
  4. #4
    Nov 2011
    Quote Originally Posted by Der0p View Post
    Saludos carnal :P
    Same for me - I just registered to say this worked for me. Many thanks to the OP.
  5. #5
    Aug 2010
    yep had this problem with my Asus G73J notebook, this fixed it.
    CHeers
  6. #6
    Nov 2011
    Registered just to be able to say that this worked for me! Thanks alot man The audio was very low before and I had to turn it up on my headphones everytime I wanted to play! Thaanks
  7. #7
    Aug 2011
    Hi all, Im having the same low sound problem with low sound on my M17x-R3!
    Im not seeing the SRS tab on my audio player in Sound (IDT High Definition Audio on mine).
    If anyone could be more specific on where this was I would be forever appreciative.
  8. #8
    I was saying boo-urns
    Mar 2008
    Rep. of Ireland Posts: Spam
    Thanks for this, worked a charm
    Today a young man on acid realized that all matter is merely energy condensed to a slow vibration, that we are all one consciousness experiencing itself subjectively, there is no such thing as death, life is only a dream, and we are the imagination of ourselves." Bill Hicks
  9. #9
    Mar 2011
    thanks works well!
    M14x R2 Black | Intel® Core™ i7 3610QM 2.3GHz | 12GB 1600Mhz Memory
    120 GB HyperX SSD + 750GB HDD | 1600x900 HD+ | 2 GB GDDR5 NVIDIA® GeForce® GT 650M
    Killer Wireless-N 1202 | Windows 8 Pro | Orion Messenger Bag | 1 Year Advanced Warranty
  10. #10
    Aug 2009
    Thanks, this worked for me too.
SEO by vBSEO 3.6.1
