Quantcast Help! M11x won't turn on (7 beeps)
Page 1 of 2 12 LastLast
Results 1 to 10 of 14
  1. #1
    Sep 2010
    Default Help! M11x won't turn on (7 beeps)
    SOLVED
    So today I took apart my m11x-r2 and when I put it back together it wouldn't turn on. What now happens is the everything will start as normal in the beginning (fan, keyboard lights) then suddenly the fan will go full throttle and there will be 7 beeps. The screen also never turns on.
    I hope I didn't break my laptop I promised this was the last time i was going to open it that far too *sigh* Anyway I looked around for what it means, tried reseting cmon battery, reconnecting all the little connection thingies, using only one ram in different spots, ect. I have run out of ideas. I was hoping someone would know what the 7 beeps mean. Please help!
    Edit: I finally fixed it, and it was the thing I should have checked first. The only variable that changed, my wwan card. I took it out and it changed to 5 beeps, I put my RAM back in and it turned to 4 beeps, finally I swtiched up the RAM slots and it booted. I put my wwan card in after it booted and it still wanted to boot so in the end I have no idea what happened really.
    Thanks to everyone that helped, sorry for not thinking of it earlier >.>
  2. #2
    Is that lemon zest?
    Mar 2010
    Minnesota
    Default Re: Help! M11x won't turn on (7 beeps)
    just did a little searching, but looks like 7 beeps is a cpu failure.
    M11x R1- c2d SU7300 | 1tb | 8gb | GT335m | Killer 1103
    M11x R1- c2d SU7300 | 128gb SSD | 8gb | GT335m | Killer 1103
    M14x R2 - i5-3210M | 1tb/32gb SSD | 16gb | GT650m | Killer 1202
    aw17 - i7-4700QM | 3tb raid | 256gb msata| 16gb | GTX780
    Alienware X51 - i5-3570k | 1tb | 16gb | GTX750ti
    Alienware Hangar 18 - i3-3225 | 12tb hdd | 4gb
    Alienware HUB - 2.1 Speaker
    Alienware CE-IV - 1gb MP3 player
  3. #3
    Jul 2011
    Swindon, UK
    Can also mean the motherboard, take it to somewhere where they are help diagnose the issue. Could be you've not seated the daughter board correctly.
  4. #4
    Sep 2010
    Oh god I hope not :'( Shouldn't there be a manual for it? Doesn't say what the beeps mean in the manual they gave me.
    That's the one with the audio jacks right? I tried resetting already as carefully as I could.
  5. #5
    Jul 2011
    Swindon, UK
    Yes the daughter board is the one with the audio jacks, is there nothing else you could have missed? In my experience (1000+ laptop rebuilds) it's quite difficult to do enough damage to break something unless you've been quite brutal or are the god of static.
  6. #6
    Is that lemon zest?
    Mar 2010
    Minnesota
    Couldnt hurt to take the whole thing apart and put it back together again... maybe you missed something the first time around.
    I have had good luck with that, had a computer not start after taking it apart, so I re-took it apart and it worked after that.
    Why did you take it apart in the first place? might give us some idea of what is causing the failure.
  7. #7
    Jul 2011
    Swindon, UK
    ^ Interested why you took it apart as well!
  8. #8
    Sep 2010
    I took it apart for two reasons, the first was to install a wwan card and the antenna behind the keyboard (I had just had the hinge serviced around half a week before so I removed it before servicing) and two, because the bottom was loose and the warranty officer told me it was due to a missing screw. I went in to replace the screw in which I had to open it all the way (which it turns out didn't help at all).
    I took the whole motherboard out although barely even touched the back side (cpu/gpu) and also tried to take the bluetooth module out but couldn't since the screw was worn out.
  9. #9
    Jul 2011
    Swindon, UK
    Oh right I see, I'd love to help further but without having it in front of me it's hard to tell.
    Are the beeps short? What happens after the beeps? Does the fan start up on maximum immediately?
  10. #10
    Sep 2010
    Yeah, thanks for the help so far. It starts up normal for a few seconds then the fan goes berserk, it then restarts, the same thing happens but this time there are 7 ~0.5 second beeps, this beeping pattern repeats indefinitely.
Copyright © 2015 vBulletin Solutions, Inc. All rights reserved.
SEO by vBSEO 3.6.1
