Quantcast SRS Technology sound - default settings anywhere?
Results 1 to 6 of 6
  1. #1
    Jan 2011
    Default SRS Technology sound - default settings anywhere?
    with SRS enabled, the bass is cranked up so high by default that it causes distortion out of my speakers. if i lower it, i'll check it again a few hours later and something (probably another program) has caused it to revert back to the original settings. bass at 70%, etc.
    any ideas on how to make a change to this setting and make it stick?
  2. #2
    Aug 2010
    BC, Canada
    Default Re: SRS Technology sound - default settings anywhere?
    Bump
    I would also love to found out how to change this. I hate having to change all the settings every time i plug in my headset because it sets the crossover too high.
  3. #3
    Jan 2011
    Quote Originally Posted by tonkatrain View Post
    Bump
    i know, right? this is really bugging me. i'm guessing there's a little registry fix. also, there's a little check box that you can uncheck that says "let other programs take control of SRS" or something to that effect. i may uncheck it, open a bunch of different programs and games, then come back and check the SRS settings again.
    in related news, i have been regularly changing the settings for the past couple days, and just the other day, my computer just froze while watching a random youtube video (480p). the sound did that frozen/loop thing, the screen froze, and the only thing i could do was a hard reset (holding the power button).
    i have since left the SRS settings alone and haven't had this problem again in the past ~48 hours.
  4. #4
    Mar 2010
    UK
    Quote Originally Posted by frescagod View Post
    You've just taught me something about my M11X - I had no idea that SRS control panel existed
    There's also an interesting looking "Loudness Equalization" option on the "Enhancements" tab...
  5. #5
    Nov 2010
    Yes. Try configuring the SRS sound through the REALTEK HD AUDIO MANAGER (there is an SRS tab in the panel) That should make it perm
  6. #6
    Notebook Virtuoso
    Sep 2007
    I see that you're going to Windows --> Sound properties.
    The only other program that I can think of that would affect that setting would be the RealTek audio control panel. Try going into there (you can find it in your Start Menu --> Programs) and seeing if changing settings there has any more permanent effect.
    Laptop Madness (w/unboxing pics): | 17 Second Boot - POST to Desktop | SSD Boots Windows 7 + Load 27 Apps in 1 Minute | SSD vs HDD Direct Comparison - Identical Drive Images
    Lenovo Y500 | Core i7-3630M | 16GB RAM | 256GB mSATA SSD + 1TB HDD | 2x GeForce 650M GPU (SLI) | 15.6" 1920x1080 Display | Etymotic ER-4P Headphones | 5.95lbs
SEO by vBSEO 3.6.1
