Quantcast Problem with "Activate Bluetooth Using Wireless Switch" - Page 2
Page 2 of 4 FirstFirst 1234 LastLast
Results 11 to 20 of 33
Like Tree1Likes
Thread: Problem with "Activate Bluetooth Using Wireless Switch"
  1. #11
    Sep 2007
    Default Re: Problem with "Activate Bluetooth Using Wireless Switch"
    hello i have same problem it tells me to look for "dfu image" what is that?
    *edit*
    nm it's in the same folder
    SXPS 16
    [T9400 2.53/4gb ddr3/ HD 3670/RGBLED LCD (1920x1080)/ 500gb HDD/ Intel 5300 & BT/Blu-ray Disc Combo]
    Asus G51Jx
    i7 720/ 8gb ddr3 @ 1333/ gts 360m 1gb/ 1080p LCD/500gb @ 7200 rpm/ BD&DVD
  2. #12
    Notebook Retailer
    Feb 2010
    Austin, TX
    Quote Originally Posted by xt3rmin8 View Post
    *edit*
    Can you grab a screen capture? Is this during installation of the Dell webpack or what?
    Brian
    Alienware Quality [M11x, M11xR2, M17xR2]
  3. #13
    Dec 2009
    Hi folks,
    I've Dell XPS 16, I'm having the same problem.
    I tried to setup the bluetooth driver, it says activate bluetooth using wireless switch. I done that but no use.
    I tired nguyenxhoang but it says connect the correct device. Mine system is bought in India. Now I'm in UK.
    Any advices welcome.
    P.S. few days before I got a message like "Bluetooth stack COM server has stopped "
  4. #14
    May 2011
    I have a Dell Inspirion M5010. I have followed Oblivion426's instructions but am running into a problem
    When running the installer it asks for me to supply a DFU file so I use the DFU file that is found inside the same folder as the installer. But it says I have to connect the proper device for it to work
    Anyone had that issue that can help me?
  5. #15
    Mar 2007
    I'm having the same problem, the DFU mode program tells me that it's not for my Bluetooth or something..
    Is it possible that my R1 does not have Bluetooth at all? Was it an add-on option?
    Current travel notebook: Lenovo Yoga 2 13" i5/4gb/500gb Hyrbrid
    Late '13 Apple iMac 780M (Triple monitor setup) Firestrike 6400+ Graphics Score
    Asus ROG Late 2013 G750JH (256GB SSD RAID0 + 480GB Crucial M4 SSD, 16gb Ballistix CAS9 RAM, 780M 4gb) 3dMark11 of 9400P
    Asus ROG 2014 G750JM 860M (Returned!)
    Asus N550JK 850M - Firestrike 3600+ Graphics Score (Returned!)
  6. #16
    Mar 2011
    Washington, Utah, USA
    It was an add-in option.
  7. #17
    May 2011
    The 2 indications I have that make me think my laptop does have bluetooth are
    01. It was enabled in BIOS
    02. The first time I got my laptop online Dell Support Center sent me a notification saying I needed to update my bluetooth drivers
  8. #18
    May 2011
    Well the 1 indication that will tell you for sure is the device manager. If bluetooth shows up there, or a device with a yellow "!" with the bluetooth ID, then you have it. If nothing shows up and all of your drivers are installed then it looks like you don't have it.
  9. #19
    Oct 2010
    If the FN+F3 wireless switch does not work and there is no bluetooth icon on the lower right corner where the applications run...
    1) check bios to make sure it's on
    2) uninstall the bluetooth driver and software (this may take out your wireless also so have the drivers handy )
    3) reboot (optional: disable bluetooth, reboot enable it)
    4) reinstall the driver software from dell.
    5) if the "activate with wireless switch" is not activating, cancel installation.
    6) go to c:/dell drivers and into the weird strand of numbers that is the dell folder containing the bluetooth driver. Go into the 64 (if you're six four) folder, run the installer, and load the .dfu file that is in the same folder of the installer when it asks you to.
    7) If that fails to detect the bluetooth, and device manager does not show a bluetooth device detected, then a fresh install of windows will fix it in most cases.
    This is assuming you have bluetooth installed and bluetooth has worked in the past.
  10. #20
    Mar 2007
    Okay i'm thinking my R1 (base model) just doesn't have bluetooth installed..
    If I want to add it in, is it a matter of replacing the Wifi card with say, an Intel card that has the BT module on the card as well?
SEO by vBSEO 3.6.1
